PropertyData object with name "" already exists
Hi, We have upgrade an site from 5.1 to 6.0. And after that we get the following error. How can we solve that?
PropertyData object with name "MainBody" already exists
[ApplicationException: PropertyData object with name "MainBody" already exists]
EPiServer.Core.PropertyDataCollection.Add(String name, PropertyData value) +130
EPiServer.DataAccess.PageListDB.ReadPageList(AbstractCommand cmd) +1226
EPiServer.DataAccess.<>c__DisplayClass14.<LoadSpecificPages>b__13() +451
EPiServer.DataAccess.<>c__DisplayClass1`1.<Execute>b__0() +58
EPiServer.DataAccess.DatabaseFactory.Execute(Action`1 method) +55
EPiServer.DataAccess.DataAccessBase.Execute(Action`1 action) +240
EPiServer.DataAccess.PageListDB.LoadSpecificPages(Int32[] pageLinks) +78
EPiServer.LocalPageProvider.GetPages(PageReferenceCollection pageReferences, ILanguageSelector selector) +173
EPiServer.Core.PageProviderBase.GetScatteredPages(PageReferenceCollection pageRefs, ILanguageSelector selector) +404
EPiServer.Core.PageProviderBase.GetChildren(PageReference pageLink, ILanguageSelector selector, Int32 startIndex, Int32 maxRows) +92
EPiServer.DataFactory.GetChildren(PageReference pageLink, ILanguageSelector selector, Int32 startIndex, Int32 maxRows) +453
EPiServer.Web.UrlSegment.GetPageBySegment(PageReference parent, String urlSegment, String languageBranch, Boolean exactLanguage) +86
EPiServer.Web.FriendlyUrlRewriteProvider.GetPageBySegments(PageReference rootPageRef, String[] segments, String languageCode) +35
EPiServer.Web.FriendlyUrlRewriteProvider.GetPageFromStartByPath(String path, LanguageBranch languageBranch) +316
EPiServer.Web.FriendlyUrlRewriteProvider.ConvertToInternalInternal(UrlBuilder url, Object& internalObject) +423
EPiServer.Web.FriendlyUrlRewriteProvider.ConvertToInternal(UrlBuilder url, Object& internalObject) +451
EPiServer.Web.UrlRewriteModule.HttpUrlRewriteToInternal(UrlBuilder url) +342
EPiServer.Web.UrlRewriteModuleBase.BeginRequestEventHandler(Object sender, EventArgs e) +158
System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +68
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +75
#46256
Dec 03, 2010 18:12
Hi Øyvind,
This forum post seems related to your problem. Perhaps it could help, http://world.episerver.com/Templates/Forum/Pages/Thread.aspx?id=15862&epslanguage=en
Regards, Leif
#46269
Dec 05, 2010 22:46
Looks a little bit like this:
http://world.episerver.com/Templates/Forum/Pages/Thread.aspx?id=45584&epslanguage=en
I've seen this error is it is a page loop to it self or using shortcut to a page that isn't there.
Kind regards,
Jon Haakon
#46289
Dec 06, 2010 16:44
I have a site that I have upgraded from 4.62B to CMS6 and from time to time I get this exact error. It just appears at random, I haven't been able to see any pattern when it occurs.
Have you found any solution to this? I looked at the links above but they didn't help.
Kind regards,
/Jens
#47250
Jan 20, 2011 15:45
This is a very old question but I recently ran across this same error.  There are several SQL queries you can run to look for duplicate property names:
-- Checks the tblProperty table looking for duplicate properties.
SELECT [fkPageDefinitionID]
	,[fkPageID]
	,[fkLanguageBranchID]
	,COUNT(*)
FROM [dbo].[tblProperty]
GROUP BY [fkPageDefinitionID]
	,[fkPageID]
HAVING COUNT(*) > 1
-- Checkes the tblPageDefinition table looking for properties with the same name.
SELECT [pkID]
	,[Name]
	,COUNT(*)
FROM [dbo].[tblPageDefinition]
GROUP BY [pkID]
	,[Name]
HAVING COUNT(*) > 1
-- Checks the tblWorkProperty table looking for duplicate properties.
	,[fkWorkPageID]
	,COUNT(*)
FROM [dbo].[tblWorkProperty]
	,[fkWorkPageID]
HAVING COUNT(*) > 1
-- Checks the tblProperty table looking for two properties with the same name attached to one page.
SELECT [fkPageID]
	,PD.NAME
	,COUNT(*)
FROM [AHAEpi_Stage].[dbo].[tblProperty] P
LEFT JOIN [dbo].[tblPageDefinition] PD ON P.fkPageDefinitionID = PD.pkID
GROUP BY [fkPageID]
	,PD.NAME
HAVING COUNT(*) > 1
If any one of these queries return results you should investiage and delete the offending data row.
#88705
Edited, Jul 26, 2014 0:16
