Strange error message when I click on root in edit mode
I get this error message PropertyData object with name "TopPic2" already exists Beskrivning: Ett undantag som inte kunde hanteras uppstod när den aktuella webbegäran kördes. Mer information om felet och var i koden det uppstod finns i stackspårningen. Undantagsinformation: System.ApplicationException: PropertyData object with name "TopPic2" already exists Källfel: Ett undantag som inte hanteras genererades vid körningen av den aktuella webbegäran. Information om undantagets ursprung och plats kan identifieras med undantagsstackspårningen nedan. Stackspårning: [ApplicationException: PropertyData object with name "TopPic2" already exists] EPiServer.Core.PropertyDataCollection.Add(String name, PropertyData value) +127 EPiServer.DataAccess.PageDB.LoadUserProperty(PropertyDataCollection propertyColl, IDataReader reader) +70 EPiServer.DataAccess.PageLoadDB.LoadPageInternal(PageReference pageLink, AbstractCommand cmd) +623 EPiServer.DataAccess.PageLoadDB.LoadVersion(PageReference pageLink, Int32 languageBranchID) +469 EPiServer.LocalPageStore.GetPageLocal(PageReference pageLink, ILanguageSelector selector) +171 EPiServer.LocalPageStore.GetPageRaw(PageReference pageLink, ILanguageSelector selector) +165 EPiServer.LocalPageStore.GetPage(PageReference pageLink, ILanguageSelector selector, AccessLevel access) +583 EPiServer.DataFactory.GetPage(PageReference pageLink, ILanguageSelector selector, AccessLevel access) +333 EPiServer.DataFactory.GetPage(PageReference pageLink, AccessLevel access) +77 EPiServer.UI.WebControls.PersonalActivity.FindPageActivities(IList`1 activities) +331 EPiServer.UI.WebControls.PersonalActivity.get_Activities() +47 EPiServer.UI.WebControls.PersonalActivity.CreateChildControls() +30 System.Web.UI.Control.EnsureChildControls() +87 System.Web.UI.Control.PreRenderRecursiveInternal() +41 System.Web.UI.Control.PreRenderRecursiveInternal() +161 System.Web.UI.Control.PreRenderRecursiveInternal() +161 System.Web.UI.Control.PreRenderRecursiveInternal() +161 System.Web.UI.Control.PreRenderRecursiveInternal() +161 System.Web.UI.Control.PreRenderRecursiveInternal() +161 System.Web.UI.Control.PreRenderRecursiveInternal() +161 System.Web.UI.Control.PreRenderRecursiveInternal() +161 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1360
#15862
Nov 07, 2007 21:28
Can you paste your code? (The code that fails) -- Lars Øyvind Bodahl www.epinova.no
#16515
Nov 09, 2007 8:40
When I changed role provider from Windows to Multiplex the problem disapeared.
#16516
Nov 15, 2007 16:35
Has anyone got a 'real' solution to this problem? Seems to have something to do with the list of unpublished pages on the Root-page.
#16517
Feb 11, 2008 10:33
I just got this problem because i changed the order of the languages. I moved swedish above english and i got the error - when i switched them back it went away. I also changed the culture in web.config to swedish from english. Im guessing its because the page that was created first was in english and there was no page for swedish created before I switched the language order so it was trying to find a default page that didnt exist? just a guess.. could be totally wrong
#16518
Mar 20, 2008 11:59
Im using CMS 5R1 I dont have "enable globalization" or "detect language via browser" enabled The properties on my pages are prepared for multilanguages with the "Unique value per language" option set Maybe this is fixed in CMS 5R1SP1 ?
#16519
Mar 20, 2008 12:02
