http://world.episerver.com/FAQ/Items/License-error-in-load-balanced-environment/
Is it relate to this?
Is the master server up before the slave one?
this might be. I see that the server with the master license is running a older version of the site db with a new host header value. I'll try to update the licence-files to match the new environment. I'll let you know how it goes
I am trying to set up two sites on two different servers in a balanced environment. I have never had problems with this before, but now on windows server2008/IIS 7 I have run into one! Following the steps in http://world.episerver.com/Templates/Forum/Pages/thread.aspx?id=42789 ,everything is going well, but when I change the enableRemoteEvents to true, the site crashes giving me a this error:
An item with the same key has already been added.
Description:
An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.ArgumentException: An item with the same key has already been added.
Source Error:
Stack Trace:
[ArgumentException: An item with the same key has already been added.]
System.ThrowHelper.ThrowArgumentException(ExceptionResource resource) +51
System.Collections.Generic.Dictionary`2.Insert(TKey key, TValue value, Boolean add) +7464156
EPiServer.Events.Remote.EventReplicationWCFProviders.AddEventReplicationProvider(String endPointName, EventReplicationProvider eventRepl) +93
EPiServer.Events.Remote.EventReplicationWCFProviders.AddEventReplicationProvider(String endPointName) +244
EPiServer.Events.Remote.EventReplicationWCFProviders.InitializeEventReplicationProviders() +106
EPiServer.Web.InitializationModule.InitializeEventService(Settings settings) +132
EPiServer.Web.<>c__DisplayClass32.<Initialize>b__12() +10
EPiServer.Web.InitializeEngine.Initialize() +228
EPiServer.Web.InitializationModule.Initialize(EPiServerSection config, Settings settings, ConnectionStringSettingsCollection connectionStringSettings) +1267
EPiServer.Web.InitializationModule.<StaticInitialization>b__2() +34
EPiServer.Web.InitializationModule.StaticInitialization() +737
EPiServer.Web.InitializationModule.Application_BeginRequest(Object sender, EventArgs e) +484
System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +68
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +75
Anybody experienced this before or got any ideas on what this is?
