Problems with load balanced site
We have a site running EPiServer CMS 5 R2 SP 2 on two servers. However the cache synchronization isn't working as supposed. I have read the article “Cache Update and Load Balancing for EPiServer CMS 5” (http://world.episerver.com/Articles/Items/Cache-Update-and-Load-Balancing-for-EPiServer-CMS-5/) without any new ideas to the source of the problem.
I have also used the “EPiServer Remote Event Listener”-tool and can see that events is correctly sent and received by the other machine when I publish a page in EPiServer. The problem is that the cache isn’t invalidated on the second server.
Any suggestions for how to proceed with the troubleshooting is highly appreciated. =)
Regards,
Karl
I have also used the “EPiServer Remote Event Listener”-tool and can see that events is correctly broadcasted and received by the other machine when I publish a page in EPiServer. The problem is that the cache isn’t invalidated on the second server.
Regards,Karl
#42789
Sep 01, 2010 14:05
Hi Karl,
What IIS are you running on 6 or 7? Also are you using the udp protocol for sending the packages?
#42790
Sep 01, 2010 14:32
Make sure both servers use the same value for the siteid attribute in site settings in web.config (episerver.config in CMS 6)
#42791
Sep 01, 2010 14:47
Thanks for your replies!
The sites are runnin on a Windows 2008 server with IIS 7 in Integrated Pipeline Mode, the udp protocol is used for sending the packages (enableRemoteEvents is set to true and endpoints are configured to send/receive using udp under system.serviceModel).
I have also double checked so the siteId-attribute is the same on both servers.
#42809
Sep 02, 2010 8:35
Hi Karl,
As your using the Integrated Pipeline Mode the EventSubscriberHostModule that you added according to the article will not be used. instead you need to add this under your module tag.
<system.webServer>
 <modules runAllManagedModulesForAllRequests="true">
<add name="EventSubscriberHostModule" type="EPiServer.EventSubscriberHostModule, EPiServer" />
#42812
Sep 02, 2010 9:41
All http handlers and modules are registered under the system.webServer section so that shouldn't be the problem. The runAllManagedModulesForAllRequests-attribute is set to true as well...
Any other ideas?
#42816
Sep 02, 2010 11:28
No running out of ideas. Are you able to post your web.configs for the two servers?
#42821
Sep 02, 2010 11:42
The web.config-files is identical on the two servers, a copy of the file is avaiable at http://pastebin.com/S60A85UL.
#42823
Sep 02, 2010 13:14
