Social Reach giving Access denied Error
We have installed Social Reach module to EpiServer 7. We have two user groups Administrators and Publishers. We created a facebook channel and given all permission to both the groups. When I login with Administrator and publish a message, it works fine. It publishes the message to facebook. But when I login with publisher and publish the message, it fails. It throws error "Failed starting workflow : Access denied". Can anyone please tell me where and which rights I need to give to the Publisher group?
#71051
May 08, 2013 9:21
Be sure that your user/group is granted access to the SocialFlow workflow (Admin - Workflows - SocialFlow (edit) - Security tab)
#71156
May 11, 2013 23:18
Hi Arild, Thanks for the reply
Unfortunately I don't see "Workflows" under Admin tab. I have logged in as Admin user. I am using EpiServer 7. Am I missing something?
Thank you
#71157
May 11, 2013 23:26
If your admin user belongs to the WebAdmins group, you should have access to Workflows in a default installation.
Are Workflows enabled in your web.config? Look for the sections described here: http://world.episerver.com/Documentation/Items/Developers-Guide/EPiServer-CMS/7/Workflows/Developing-Workflows/#Configuration
If workflows are indeed enabled, maybe the Workflow menu option is disabled:
- Go to Admin mode > Config tab > Plug-in Manager.
- Click EPiServer User Interface > Overview tab.
- Scroll down and make sure "Workflows (AdminMenu)" is checked.
#71158
May 12, 2013 1:50
Thank you again Arild. With your suggestions I am able to enable the Workflows menu and I see, the SocialFlow workflow. Now I am facing the next problem. I Went to Edit Workflow => Security tab=> Add User/Groups. I added a group and assigned some rights. Then I clicked Save button. Now the screen gets refreshed and the stayed back to General tab. The assigned rights are not saved. I tried several times but not able to save. What could be the problem?
#71163
May 13, 2013 8:50
You probably clicked the Save button on the bottom of the page, this will not save the new group rights correctly (bug perhaps).
There is another Save button directly below the "Add user/group" button, that will save your changes correctly.
http://i.imgur.com/FXwH3jY.png
#71164
Edited, May 13, 2013 9:54
oops, I did not see those buttons. Not it works fine. Thank you
#71569
May 22, 2013 15:31
Hi Anrid,
I have another problem, which was working earlier. In the social reach Settings, if I click "Edit account" for the twitter account, it opens a page and throws "Unauthorized exception" as below. Do you have any clue, what could be the problem? Thanks for your answers
Page could not be loaded
The link you specified does not work. This may either be the result of temporary maintenance or an incorrect link.
Detailed error information (authorized by permissions to functions)
Error occured 7/18/2013 4:48:57 PM
User IP 10.0.17.1
User Agent Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.1; WOW64; Trident/6.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; .NET4.0E; NP06; BRI/2)
Url http://www.diamondleague.com:80/eui/EPiServer.Social/Providers/Twitter/TwitterLogin.aspx?redirect=1
Referer (none)
The remote server returned an error: (401) Unauthorized. Server Error in '/' Application.
Exception Details: System.Net.WebException: The remote server returned an error: (401) Unauthorized.
Source Error:
Stack Trace:
[WebException: The remote server returned an error: (401) Unauthorized.]
   System.Net.HttpWebRequest.GetResponse() +7866548
   DotNetOpenAuth.Messaging.StandardWebRequestHandler.GetResponse(HttpWebRequest request, DirectWebRequestOptions options) +261
[ProtocolException: Error occurred while sending a direct message or getting the response.]
   DotNetOpenAuth.Messaging.StandardWebRequestHandler.GetResponse(HttpWebRequest request, DirectWebRequestOptions options) +1838
   DotNetOpenAuth.Messaging.Channel.RequestCore(IDirectedProtocolMessage request) +200
   DotNetOpenAuth.Messaging.Channel.Request(IDirectedProtocolMessage requestMessage) +138
   DotNetOpenAuth.Messaging.Channel.Request(IDirectedProtocolMessage requestMessage) +45
   DotNetOpenAuth.OAuth.ConsumerBase.PrepareRequestUserAuthorization(Uri callback, IDictionary`2 requestParameters, IDictionary`2 redirectParameters, String& requestToken) +202
   DotNetOpenAuth.OAuth.WebConsumer.PrepareRequestUserAuthorization(Uri callback, IDictionary`2 requestParameters, IDictionary`2 redirectParameters) +28
   EPiServer.Social.Providers.TwitterLogin.OnInit(EventArgs e) +832
   System.Web.UI.Control.InitRecursive(Control namingContainer) +133
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1970
#73411
Jul 18, 2013 17:37
I believe it's because Social Reach used the old Twitter Api v1.0 which has been discontinued (see this thread).
Also EPiServer 7.1 and newer includes an updated Social Reach plugin. Try upgrading your site to 7.1 or reinstalling Social Reach from the Add-On Store to see if that helps.
#73412
Jul 18, 2013 21:23
