Social Reach and Twitter
I've just installed Social Reach, but I'm having problems setting up a Twitter channel.
Facebook and LinkedIn work fine, but Twitter will not authorise and I get the following error:
DotNetOpenAuth.Messaging.ProtocolException: Error occurred while sending a direct message or getting the response. ---> System.Net.WebException: The remote server returned an error: (401) Unauthorized.
Does anyone know what the issue could be? Maybe something to do with Twitter's depreciation of the v1 API?
Robert
#71066
May 08, 2013 11:53
Yup, broken because old Twitter API is deprecated. See https://twitter.com/kloojed/statuses/292621633229836288
#71068
May 08, 2013 12:25
Ah, I thought so!
Do you happen to know if this patch was ever released?
Robert
#71069
May 08, 2013 12:30
No, sorry. I see you contacted @episerver on Twitter, you could also try @kloojed who seems to know how to fix it.
Please update this thread with the solution if you find it :-)
#71071
May 08, 2013 12:39
Will do, thanks for your help.
Robert
#71072
May 08, 2013 12:51
I solved it by modifying the static field containing the endpoint at application start up.
            var field = typeof(EPiServer.Social.Providers.Twitter.TwitterClient).GetField("UpdateStatusEndpoint",
                     BindingFlags.Static |
                     BindingFlags.NonPublic);
            // Normally the first argument to "SetValue" is the instance
            // of the type but since we are mutating a static field we pass "null"
            field.SetValue(null, new MessageReceivingEndpoint("https://api.twitter.com/1.1/statuses/update.json", HttpDeliveryMethods.PostRequest));
Marcus
#71151
May 11, 2013 12:32
Thanks Marcus.
Unfortunately I can't even set up the Twitter channel as it won't authenticate.
How did you get around this?
Robert
#71169
May 13, 2013 11:10
I'm not sure what you mean, can you add the twitter channel but when you try to authenticate it fails?
#71215
May 14, 2013 13:10
I can't actually add a Twitter channel, an error is thrown when I click the "Edit Account" link.
Robert
#71216
May 14, 2013 13:25
Ok, what does the error message say? I had one issue with Newtonsoft.json, I used the wrong assembly version which caused a error for me.
#71217
May 14, 2013 13:32
The error is:
#71218
May 14, 2013 13:33
Hm sorry, I out of ideas ... maybe you could check the dotnetopenauth settings in web.config, I think the whitelistHosts setting is important if you are running your site locally.
#71220
May 14, 2013 13:41
We have now updated social reach for cms 6 r2 to support the new twitter api + a few more things. You can download it here: http://world.episerver.com/Download/Items/EPiServer-Social-Reach/EPiServer-Social-Reach-1-Beta/
There is also a new "latest downloads" box on the downloads page where you can track everything we release.
#71336
May 16, 2013 8:39
Hi Peter,
That's brilliant news, thank you.
The download link doesn't seem to work though, I get a Page Not Found error when I try to download.
Robert
#71346
May 16, 2013 10:21
Hi, sorry for the inconvinience that the download did not work. But it is fixed now.
#71360
May 16, 2013 12:43
Thank you Helen and Peter.
I have downloaded and installed this update and it seems to have fixed the issue I was having.
Regards,
Robert
#71458
May 20, 2013 10:55
