Service API Get Catalogs 404
i have found this topic
https://world.episerver.com/forum/developer-forum/Episerver-Commerce/Thread-Container/2017/10/getting-404-when-posting-catalog-zip-to-episerverapicommerceimportcatalog-from-c-/
I am trying to get the Catalog (https://world.episerver.com/documentation/developer-guides/Episerver-Service-API/catalog-restful-operations/Catalog/#get_catalogs)
But getting 404.
My users are setup in the system ( i have 2) one user is in WebAdmin and WebEditor groups and the second one is in Administrators and Web/Admin/Editor.
I have configured the permissions in the Admin mode so that both Administrators and WebAdmins have read/write permissions for Service Api
The SSL is disabled in Web.Config -> ApplicationSettings
I have also tried to
<add key="episerver:serviceapi:maphttpattributeroutes" value="false" />
I am using postman.
Steps:
1. I generate a token for the user (tried with both users).
2. Than in postman i select [GET] to (CMS) http://localhost:14432/episerverapi/commerce/catalogs
3. In Postman, under Authorization, i select Type : Bearer Token and past the token  that i got under step 1.
4. Click [Send]
Result: 404
My catalog is very simple. I have a catalog called Alloy and just one Category page.
As mentioned the get version (currently on version 5.2 (is working)) and the Token is generated.
But as soon as i try a get operation concerning getting any catalog data (also tried to get my specific catalog named Alloy) i get 404
I have setup the the Alloy and than installed Commerce.
The site is up and running and i can see both my Category page and the default Alloy pages.
Any suggestions?
#199431
Nov 27, 2018 15:21
This should not be used unless you have other code that specifically calls MapHttpAttributeRoutes
And how do you generate the token? don't you have to post to episerverapi/token to get it?
#199461
Nov 28, 2018 8:52
As it sometimes happens, it solved it self, very strange.
I restarted the computer and it was working???
#199802
Dec 12, 2018 8:11
