Getting 404 when posting catalog.zip to /episerverapi/commerce/import/catalog from C#
as a proof of concept I have a clean Alloy Tech CMS extended with Commerce nuget package. I have installed Service API for Commerce nuget package in the CMS part and was able to get the access token when posting to /episerverapi/token
I have followed instructions given here and I keep getting 404 when posting the catalog.zip to the /episerverapi/commerce/import/catalog from C# code. This happens both on localhost (http and https) and on test environment on azure.
Does anyone know if something has changed recently in URL signatures compared to the instructions?
#183781
Oct 23, 2017 13:57
No, the Url is a part of the public "API" so they can't be changed without a major release - and no we haven't changed that.
Did you try postman to do the posting? How does your request look like? Did you try with some GET APIs?
#183794
Oct 23, 2017 16:19
Yes, I did try postman.
GET requests also return 404
for example here is the request for /episerverapi/commerce/catalogs
GET /episerverapi/commerce/catalogs HTTP/1.1
Host: localhost:44358
Authorization: bearer YjEYPG1S1IDRl-XirJAH91T-R4WWaDPq6c9-Dy10oxtKx2CN6y4UhqBC4tPuys-BLoQJ-ihTCqfaLl2nu61XInC0EQXAmpKZvE14ME5fPhIjPntPBsSHU0wBen8YN6lip1iZzUrXuL2xOwyfDYgN5t17QM2nJJhWUxGLfOktE4HD206Zk3HtuQDIHxjtRhlSRSdRUGsPV1UBWvBfdGc_OacFCCMGfADuN0NNPrwwCT69e0-1zY9u4NepVzLvyaGqZQ3i8iaieyXDa9iNBP7VII4mEUxB-B1v2UNVWH4atUhw-6F1GBM5b5xhS6IBADxEA9K3Z0Luj8u93lGCkXP8HWwONmfM6oHN_SwWat0exUQkHlHqxDJN_shM-Ie7c1ppfvq8vr90Bx6J_A4VMbHUQLIORgMOzOYgNtdziVQSTuzaBu8kfUMndSkvrYjzUAlZcLKggLGXH6EE5oBcUxqBBYNNfSFKsJzh0iHLe8Z-8kPSTJqbe0CyOlTwWXPHeHHO
Cache-Control: no-cache
Postman-Token: f3cd363a-c69b-1718-a889-246ddabcfc72
and here is the request for the /episerverapi/commerce/import/catalog
POST /episerverapi/commerce/import/catalog HTTP/1.1
Host: vanillacommerce.azurewebsites.net
Authorization: bearer pLgAViNNgOfK90_9yIP-9_dYK2uc-_uzx-SES6QicJ5ecPmCkV8kKvca82TY4gcfDg0fg_KsFp5bSA4CSvWIi4IeSd6Mxwg4VTaTFaIR6AKvgLddJTuS9jXrMF2UlTq7CWNMXnM9NNGFOoSkfceWEe1RxBDFgGg-9TW3_O0_ucg7OxucqYHPiuvl5JfSo5Zs10SrkS6nhHvQGmb6BMj76GRmj5eYSYF4ckWkuOfioJWHZVtVBtiUbXsfwruFRL8AHNo6v6E7oTRMPP08llk9bR4FaYHJPjSOPVx7zapGdCXPd5rZbULG4d-8CwQFdnX9My4LLH_0TJ3IyFtlQzHkZg8eB8nPwariOjrsbacvvGgdwzzt8uhfeaZrrSTEKJCp5gDPHaw81HYbR1MxY1uu_WT_U36HzBJjvXLfFygzAKZCyM7E7zijeIZKog5V_VHDsPE2hAPxg-YMGhSVSGf40SPzwv0prVP-VgesICN2uwrU1KkeUbiYMP5Pdo1rXBjJ
Content-Type: multipart/form-data; boundary=----WebKitFormBoundary7MA4YWxkTrZu0gW
Postman-Token: 898fb270-2e33-38d4-2ee1-7241494167a5
------WebKitFormBoundary7MA4YWxkTrZu0gW
Content-Disposition: form-data; name=""; filename="catalog.zip"
Content-Type: application/x-zip-compressed
------WebKitFormBoundary7MA4YWxkTrZu0gW--
Implementation of the Configuration(IAppBuilder app) is like this
public void Configuration(IAppBuilder app)
            app.AddCmsAspNetIdentity<ApplicationUser>();
            app.UseAdministratorRegistrationPage(() => HttpContext.Current.Request.IsLocal);
            app.UseCookieAuthentication(new CookieAuthenticationOptions
                AuthenticationType = DefaultAuthenticationTypes.ApplicationCookie,
                LoginPath = new PathString(Global.LoginPath),
                Provider = new CookieAuthenticationProvider
                    OnValidateIdentity = SecurityStampValidator.OnValidateIdentity<ApplicationUserManager<ApplicationUser>, ApplicationUser>(
                        validateInterval: TimeSpan.FromMinutes(30),
                        regenerateIdentity: (manager, user) => manager.GenerateUserIdentityAsync(user))
            app.UseServiceApiIdentityTokenAuthorization<ApplicationUserManager<ApplicationUser>, ApplicationUser>();
I imagine now that something is not implemented right but what confuses me is the fact that I could get the token from the GET request to /episerverapi/token
#183885
Oct 24, 2017 9:39
Nice job Goran - this is a kind of question that I'd want to see more on World - you spent time investigating the problem, and you express it in a way that easier for us (or me at least) to understand.
I would assume that you have this in your appSettings episerver:serviceapi:maphttpattributeroutes to false?
#183910
Oct 24, 2017 12:08
Yes.
Both that setting and
episerver:serviceapi:requiressl
are set to false.
When doing everything from the beginning I was getting YSOD in case that setting was not in place. Just now, when trying to replicate YSOD by removing that specific setting, it passed without a glitch, so I gave it another go in the Postman. This time I got a 401 error 'User is not authorized for this request'.
Moreover, when tried to implement this on the latest Quicksilver solution installed from GIT I kept getting invalid_grant event when accessing the token URL. I didn't have time to investigate more on the implementation of Quicksilver but I found out that when creating CMS admin user in vanilla implementation I can log into CMS as admin and can get a nice token using those credentials, but when creating a new CMS admin in Quicksilver (no matter if username was in a form of user@domain.com or just username) due to redirection to Login page I could use only username that was in a form of email address but in any case I couldn't login as admin into CMS. This causes, in my opinion, that invalid_grant response when trying to get the token with those credentials.
This is what I need to solve next after I sort out 404 in the question.
#183914
Oct 24, 2017 12:36
Unless if you are calling config.MapHttpAttributeRoutes(); yourself, then you should not set that to false. I think it returns 404 because the route attributes were not properly mapped
#183919
Oct 24, 2017 14:02
Looks like it. 401 means that the user was not authorized as I wrote in my previous answer.
Which user group should user belong to in order to get acceptable token? If it's related to user groups at all. Both test users that I created belong to WebAdmins group.
#183923
Oct 24, 2017 15:06
Go to admin mode, Config / Permissions to Functions.  Find the Read Access and Write Access for Serviceapi and update to include WebAdmins role.
#183940
Oct 24, 2017 19:56
<p>Mark thank you. Here is an update. When following 'the path from the scratch' nuget packages add only read/write access rights to Administrators group in the table&nbsp;tblUserPermission.&nbsp;Even <a href="https://world.episerver.com/documentation/developer-guides/Episerver-Service-API/installation-and-configuration/">here</a> it says you need to check it up in the step 9. Yet the only existing group (from scratch) that user can be placed into is WebAdmins.&nbsp;</p> <p>So besides your solution developer can&nbsp;manually create Administrators group in the admin mode and place user into that group and that solves 401.</p>
#183969
Oct 25, 2017 9:27
