Language?
How do I figure out on a view page (Razor code) what language is being used so as to render the view slightly different for international?
#191918
May 02, 2018 19:28
Hi Daman,
If you for example look at Episerver Alloy sample site implementation and the _Root.cshtml layout file you can see that current language for html lang attribute is rendered using Model.CurrentPage.Language.TwoLetterISOLanguageName.
So on your view page you can use this same approach or other properties from the Language (CultureInfo object) to decide changes in the view per language.
#194495
Jun 22, 2018 10:46
