Can't log in to example project
Hey Everyone,
I am getting up to speed on this stuff and trying to go through this tutorial (below).  When I try to log in with my Windows credentials (step 6), I get directed back to the login page.  I am guessing my user is not one of these roles.  How do I find what role my user is in and change it?
from web.config
Create a starter project
https://world.episerver.com/documentation/developer-guides/CMS/getting-started/creating-a-starter-project/
#197730
Oct 11, 2018 16:09
Hi Stewart, WebEditors and WebAdmins are Episerver default groups so you are not a member of those (as those don't exists in your computer local groups unless you create those). So the assumption is that developers are local Windows administrators - so if you can't log in, you most likely are not a Windows local administrator (member of the Administrators group)?
So if you are not a windows local admin you could modify the web.config and allow access for Users groups (as you definetly are a member of this windows group :D) OR some other windows group you are a member of.
So you need to replace the 'Administrators' string in web.config with 'Users' in three places:
under:
<virtualRoles addClaims="true">
<add name="CmsAdmins" type="EPiServer.Security.MappedRole, EPiServer.Framework" roles="WebAdmins, Users" mode="Any" />
under:
<location path="EPiServer">
<allow roles="WebEditors, WebAdmins, Users" />
under :
<location path="EPiServer/CMS/admin">
<allow roles="WebAdmins, Users" />
(above making the assumption in the location paths that you have not changed the 'uiUrl' from default)
Let us know if this helped you.
#197795
Oct 13, 2018 20:52
