ssl on login.asp for extranet
How do I enable ssl for a specific page ? like on the login from the extranet. SSL is configured on the IIS.
#25016
Oct 09, 2008 15:03
Before the page is loaded, check if it's a ssl page accessed with http. If so, redirect to the same page with protocol https and the correct https port.
Also make sure you have a valid ssl server certificate supported by the major browsers.
#25035
Oct 09, 2008 21:47
