Multiple sites, multiple codebases, same filearchive?
How do i make several codesbases (which share a single database) share archive? Is a simple Virtual direcotry in IIS for /upload enough? Or should I install some 3. party sync software and sync the archives?
#16911
Apr 07, 2006 13:00
Many ways, depending on what you want to achieve. You can use a unified file system folder (http://www.episerver.com/downloads/Documents/TechNotes/EPiServer%204.60/All%20Technical%20Notes/Unified%20File%20System.pdf) if you don't need the load balancing possibility. /Øyvind ElektroPost Norge
#17070
Jul 05, 2006 11:13
