Running EPiServer on 64-bit Windows
Has anyone installed EPiServer on 64-bit Windows in WOW64 mode (AMD64 or Intel EM64T hardware)? The full 4 GB process memory space made available to 32-bit applications running on WOW64 will make ASP.NET significantly more stable, according to Microsoft. The vast majority of 32-bit ASP.NET-applications should run flawlessly on WOW64, but it would be nice to hear from someone who has actually tried it out!
#16901
Feb 03, 2006 14:20
Have a look at the bottom of this thread: http://www.episerver.com/templates/ForumItem____7070.aspx
#17058
Feb 21, 2006 9:34
Thanks for the info! I'm curious though, did you follow all the instructions on configuring WOW64 on IIS 6 SP1 carefully? For instance: Windows Server 2003 SP1 enables WOW64 compatibility for 32-bit Web applications in IIS 6.0 http://support.microsoft.com/kb/895976 Changes to HTTP API in Windows Server 2003 SP1 http://www.microsoft.com/downloads/details.aspx?FamilyId=A3DA3D7F-18C7-45CE-A47A-ED747DACEF34&displaylang=en Inside Microsoft.com - Making the Move to x64 http://www.microsoft.com/technet/technetmag/issues/2006/01/InsideMSCOM/default.aspx
#17059
Feb 23, 2006 0:12
Yes, I did, very carefully. But, as described in the other thread, EPiServer runs just fine. The only issue is with this date thing... and it only appears when importing anything.
#17060
Feb 24, 2006 11:27
