This is true, title is bad on links, on all tag except one, title should only exists on iframe-tag. For screenreaders.
Here's a blog post about hiding the Title property in the built-in Link dialog via an EditorDescriptor: https://world.episerver.com/blogs/Linda-Mohacsi/Dates/2017/10/hiding-properties-in-the-built-in-link-dialog/
Reposting the code in case the blog ever disappears:
[EditorDescriptorRegistration(
TargetType = typeof(LinkModel),
EditorDescriptorBehavior = EditorDescriptorBehavior.ExtendBase)]
public class EpiLinkEditorDescriptor : EditorDescriptor
foreach (var prop in metadata.Properties)
if (prop.PropertyName == "Title")
prop.ShowForEdit = false;
According to our UX designer the "title" attribute is bad for accessibility on links.
Here's more information about titles and accessibility: https://a11yproject.com/posts/title-attributes/
The title attribute can be added when inserting a link in TinyMCE.
We would like to remove this option to make it easiser for web editors to add accessible html.
I hope this makes sense.
Thank you
