Required attribute per event/SaveAction or alike to avoid "create view with required fields only"
We have request for customers that models with Required-attributes should not render that "create view with required fields only", inexperienced users gets confused and don't understand where all other fields are.
If we could set [Required(SaveAction.Publish)] or something, we could tell that these Required-fields are required when publishing, not for creating etc.
Or maybe there should be a possibility to annotate the model with something that forces showing complete edit view on creation?
I understand the customers request and feel it would be a nice feature to make a more solid experience for some customers.
#210716
Edited, Dec 04, 2019 9:12
Tomas Hensrud Gulla
You could create your custom validation attribute, like this:
[AttributeUsage(AttributeTargets.Property | AttributeTargets.Field)]
public sealed class RequiredForPublishAttribute : ValidationAttribute
	const string defaultMessage = "{0} is a required property!";
	private bool IsDefaultMessage = true;
	public PropertyRequired()
	public PropertyRequired(string message)
		ErrorMessage = message;
		IsDefaultMessage = false;
	public override bool IsValid(object value)
		return !value.IsNull();
	public override string FormatErrorMessage(string name)
		return IsDefaultMessage ? string.Format(defaultMessage, name) : ErrorMessage;
...then just replace [Required] with [RequiredForPublish].
#210721
Edited, Dec 04, 2019 10:35
