You could put your own version of the FormContainerBlock in ~/Views/Shared/ElementBlocks with the extra css class that you need? And disable the defaultForms stylesheet if you need to as well in Form.config in ~/modules\_protected\EPiServer.Forms. Won't that give you enough customization options?
You're partially right, but what I want to do is to customize chosen fields of my form, let's say "Last name" (text input) field needs to be red and "Sex" (select box) field needs to be green. Then I need to:
I see some serious issues here:
I need to create N new classes for each field type, I have to create N new views for each field type copying markup from base views. Now, when EpiServer decides to change anything in their base views/model - I'm screwed.
IMHO: it's very basic need to be able to set CSS class to a form element (and actually a form container as well) and I was pretty surprised when I didn't find an option to do so
Currently there's no way to customize look and feel of single form element.
It would be nice to have a text field to input css class which will be rendered when rendering form element so we can do css customization
