Possibility of exporting blocks
Can we have featurein episerver which supports export of blocks independently ?
At the moment if i would like to export and import block from one system to other . Only way is to attach blocks to  a page and then export page and import it back to get blocks moved from one systestm to other.
It would be so useful to have export Wizard offering to select the block root or specific block to be exported from one system and imported to another system.
#152233
Aug 22, 2016 4:59
Thanks for the feedback!
Your request lines up with a number of other improvements people have been asking for related to transporting content between instances. I have added this as another cornercase to consider when we refine this part of the system.
#152240
Aug 22, 2016 12:02
Thank you Martin.
#152267
Aug 22, 2016 22:31
Yes, that would be rather usefull to move blocks from e.g. the test/development enviroment to the production environment, especially if the blocks are complexe or many of them in need to be moved.
#172529
Dec 06, 2016 11:47
Check out the upcoming improvements of export and import
http://world.episerver.com/blogs/Johan-Bjornfot/Dates1/2016/11/exportimport-improvments/
#172534
Dec 06, 2016 12:35
Nice, thank you for the info.
#172537
Dec 06, 2016 12:52
Awesome and good to see request being considered and now is part of new version:)
#172768
Dec 11, 2016 21:02
