Manual installation instruction
"Deployment Center" is cool for test sites, but in large setups I often need to reverse engineer, whatever the installer did, so I can add the changes to an existing solution under version control.
The larger the setup, the less likely it is, that I can use Deployment Center directly.
In that case, it would be very helpfull to have manual installation instructions, and not only the "black box" Deployment Center.
#51280
May 31, 2011 13:45
