Can you access Community admin UI with different user and check user you are using in which *community* groups he/she is?
If we are looking at menu provider for the community module then menu item is provided if user "is Community admin".
return user.TotalAdministrativeAccessRights.EPiServerCommon;
Tracing down the path we can see that those administrative access rights are fetched by EPiServer Common module by executing
[spEPiServerCommonGetUserGroups] procedure which actually reads data from tblEPiServerCommonGroupUser table. Try to check those groups and see what's written there and how groups are synced.
I have configured the Multiplexer to use ActiveDirectory provider, and I have granted access to the groups (both in web.config and EPiServer on root level). But I can't log in either in Relate or in Edit/Admin mode. In the EventLog on the Domain Controller I can see that the user I tried to log in with have successfully logged on to the domain, but relate is able to handle. If i write wrong username/password relate does give an error, but with correct credentials it says nothing.
Anybody think of anything that can help?
Regards,
Ishan Jain
