There must be at least one site configured for the application to start
After migration from Relate+ 1 to Relate+ 2 I'm having trouble getting the site up and running.
I assume it's a web.config related issue, however I've compared it to a clean installation of
Relate+ 2 but can't find the root to the problem. Any suggestions?
My yellow screen of death:
There must be at least one site configured for the application to start.
Exception Details: System.Configuration.ConfigurationErrorsException: There must be at least one site configured for the application to start.
Source Error:
[No relevant source lines]
Source File: c:\Windows\Microsoft.NET\Framework\v2.0.50727\Temporary ASP.NET Files\root\df51bec1\7a459c3b\App_global.asax.7nc5qile.0.cs Line: 0
Stack Trace:
[ConfigurationErrorsException: There must be at least one site configured for the application to start.]
   EPiServer.Community.Configuration.EPiServerCommunitySection.OnPostInit() +305
   EPiServer.Common.Configuration.ConfigurationSectionBase`1.GetInstance(String sectionName) +365
   EPiServer.Community.Configuration.EPiServerCommunitySection.get_Instance() +16
   EPiServer.Community.Search.SearchHandler.Initialize() +84
   EPiServer.Community.Search.SearchHandler..cctor() +86
[TypeInitializationException: The type initializer for 'EPiServer.Community.Search.SearchHandler' threw an exception.]
   EPiServer.Community.Search.SearchHandler.add_UpdatingIndex(UpdateIndexEventHandler value) +0
   EPiServer.Templates.RelatePlus.Templates.RelatePlus.InitializationModules.SearchHandlerModule.Initialize(InitializationEngine context) +56
   EPiServer.Framework.Initialization.InitializationEngine.InitializeModules() +337
   EPiServer.Framework.Initialization.InitializationEngine.Initialize(HostType hostType) +82
   EPiServer.Framework.Initialization.InitializationModule.StaticInitialization(HostType hostType) +154
   EPiServer.Framework.Initialization.InitializationModule.FrameworkInitialization(HostType hostType) +65
   EPiServer.Global..ctor() +54
   PTK.Web.Global..ctor() +29
   ASP.global_asax..ctor() in c:\Windows\Microsoft.NET\Framework\v2.0.50727\Temporary ASP.NET Files\root\df51bec1\7a459c3b\App_global.asax.7nc5qile.0.cs:0
   System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandle& ctor, Boolean& bNeedSecurityCheck) +0
   System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean fillCache) +86
   System.RuntimeType.CreateInstanceImpl(Boolean publicOnly, Boolean skipVisibilityChecks, Boolean fillCache) +230
   System.Activator.CreateInstance(Type type, Boolean nonPublic) +67
   System.RuntimeType.CreateInstanceImpl(BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes) +1051
   System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes) +111
   System.Web.HttpApplicationFactory.GetSpecialApplicationInstance(IntPtr appContext, HttpContext context) +215
   System.Web.HttpApplicationFactory.FireApplicationOnStart(HttpContext context) +8888824
   System.Web.HttpApplicationFactory.EnsureAppStartCalled(HttpContext context) +136
   System.Web.HttpApplicationFactory.GetApplicationInstance(HttpContext context) +92
   System.Web.HttpRuntime.ProcessRequestInternal(HttpWorkerRequest wr) +289
#51523
Jun 13, 2011 11:13
I know you solved this already, but in case anyone else encounters similar problems:
The sites have to be correctly configured in all of the following sections: episerver.framework, episerver.common, episerver.mail and/or episerver.community. The siteId:s must match.
#51525
Jun 13, 2011 13:38
Jun 13, 2011 13:41
Reusing this thread for the same issue. I get the same error on an CMS 6 R2 site. I have double checked that the siteIds matches between the config-files.
#113102
Nov 13, 2014 9:53
