All of your examples look like they should work, we will look into this and get back to you...
Thanks! Some more information that might be of interest:
I have tried the configurations with readonly="false" too, but no difference.
The 10.1.74.1 IP address that shows up isn't actually the client address, I guess it's visible to the server as this address because of some router/DMZ or VM configuration. But the client's address (as reported by the client) is in the 172.17 range also included.
Update: We have now changed the firewall config to use the client's real IP. That didn't make any difference. I currently have this config:
<add name="dev" description="dev" ipAddress="172.17.0.0/16" allowLocal="true" />
And I get these kinds of messages in the log:
2011-01-18 11:00:17,063 [15] ERROR - No match for client IP 172.17.18.89. Access denied for access key dev.
There is a hotfix in the works for the search service which will include a fix for the issue causing this as well as the issue causing the escaping issue causing http://world.episerver.com/Templates/Forum/Pages/Thread.aspx?id=46912&epslanguage=en
Yes there is a hotfix available, but you must request it from the EPiServer support.
I think it should also be included in the R2 versions of CMS and Relate?
One way of getting around this can be to create a name in the hosts file (C:\windows\system32\drivers\etc\hosts )
10.1.1.50 Site1
and then put the site1 name in the hostheader/bindings of the site in the IIS.
For sites with an internal ip and external ip address we got this errormessage; No match for client IP xx.xxx.xx.xx. Access denied for access key local. Solution for Patrik worked. EPiServer version 8.1.
I'm setting up Full Text Search on a different machine. In the section <episerver.search.indexingservice><clients> i have tried to configure the remote machines ranges, but all of the below render the same error message in the log:
2011-01-14 08:44:08,985 [10] ERROR - No match for client IP 10.1.74.1. Access denied for access key dev.
These are the client configs i have tried (there are two subnets needed, but the test machine as you can see accesses the server through 10.1.74.1):
<add name="dev" description="dev" ipAddress="172.17.0.0/16,10.1.74.0/24" allowLocal="true" />
<add name="dev" description="dev" ipAddress="172.17.0.0/16,10.1.0.0/16" allowLocal="true" />
<add name="dev" description="dev" ipAddress="172.17.0.0/8,10.1.0.0/8" allowLocal="true" />
<add name="dev" description="dev" ipAddress="10.1.74.1/8" allowLocal="true" />
So it seems no matter how large I make those ranges, or even if I add just the range used, it still doesn't work. And once again the classes I need to test this at a lower leve are internal so I can't see where it goes wrong.
