Any reason why you are using GetQueryResults?
I would create a function like this:
private static MessageCollection GetRecentlyCreated(RoomBase room, int page, int pageSize, out int totalItems)
// Recently created
TopicSortOrder sortOrder = new TopicSortOrder(TopicSortField.Created, SortingDirection.Descending);
MessageCollection topics = ForumHandler.Instance.GetTopics(new RoomCollection { room }, EntityStatus.Approved, page, pageSize, out totalItems, sortOrder);
return topics;
Then also add, if you don't have an addition to your pagebase that gets the CurrentRoom you want to fetch from:
public RoomBase CurrentRoom
get
int roomId;
if (Request.QueryString["roomId"] != null && Int32.TryParse(Request.QueryString["roomId"], out roomId))
return ForumHandler.Instance.GetRoom(roomId);
return ForumHandler.Instance.GetRoom(-1);
Then fetch the items and add them to a listview or something similar
int totalItems; lstView.DataSource = GetRecentlyCreated(CurrentRoom, 1, 5, totalItems); lstView.DataBind();
If you still want to use the QueryResult function, add this to the query:
query.Room = new RoomCriterion();
query.Room.ID = new IntegerCriterion();
query.Room.ID.Includes = new IntegerInCriterion();
query.Room.ID.Includes.Values.AddRange(roomIDs);
where roomIDs is the ids of the rooms in the forum you want get topics from.
// Regards, Torbjörn
I am currently working with Relate plus 1. What version do you work in? Anyways, this is how I solved it.
TopicQuery topicQuery = new TopicQuery();
topicQuery.CreateDate = new DateTimeCriterion();
topicQuery.Room = new RoomCriterion();
topicQuery.Room.Parent = new RoomCriterion();
topicQuery.Room.Parent.Forum = new ForumCriterion();
topicQuery.Room.Parent.Forum.ID = new IntegerCriterion();
topicQuery.Room.Parent.Forum.ID.Value = ForumIDForTheForumYouWantToSearch;
CriterionSortOrder critSort = new CriterionSortOrder(topicQuery.CreateDate, EPiServer.Common.Sorting.SortingDirection.Descending);
topicQuery.OrderBy.Add(critSort);
MessageCollection topics = QueryHandler.GetQueryResult<EPiServer.Community.Forum.Topic, MessageCollection>(topicQuery, 1, ThreadsCount);
Hope this helps :-)
I would like to display the 5 latest topics from a forum.
Currently my code loks like this:
The problem is that this gets topics from all the different forums. How can I get topics from a specific forum?
