Membership DB migration
afternon,
I have an existing aspnet membership db that contains users from a community I'm porting to  Relate Plus.
I'd like to use the exisitng aspnet menbership db within Relate Plus?
I've found that creating new users populates just the tblEPiServerCommonUser table.
Is there away to utilise the existing username/passwords?
thanks in advance
Efe
#29343
Apr 21, 2009 17:01
Hi Efe,
You can probably use the EPiServerCommonIntegrationMembershipProvider (if you are using the Relate+ templates you'll find it in web.config) which enables you to use another membershipprovider but saves user data to the community frameworks own system as well. I would however recommend you to migrate the users if possible as you will then be able to use the built in user management interface.
#29346
Apr 21, 2009 21:23
cheers Joel,  that was a good tip I beleive I can progress form there Cool
Efe
#29361
Apr 22, 2009 12:44
