After Install Episerver Mail, i got this error
Could not load file or assembly 'log4net, Version=1.2.10.0, Culture=neutral, PublicKeyToken=1b44e1d426115821' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
#149270
May 27, 2016 13:02
Add that assembly to bin folder?
You can always steal it from an alloy site of the same version...
#149273
Edited, May 27, 2016 13:36
Thanks daniel, after resolving i got "Object reference not set to an instance of an object" issue. please refer the following link
https://drive.google.com/file/d/0B1PRzSzZOFnDTEtTRmd2OGtKTlk/view?usp=sharing
#149282
May 27, 2016 15:30
You are missing some web.config sections that are required would be my best guess. Check again on the machine you actually installed Episerver mail on...
#149285
May 27, 2016 16:00
hi daniel,
i got same error and this my web config file
For more information on how to configure your ASP.NET application, please visit
http://go.microsoft.com/fwlink/?LinkId=169433
<configuration>
<configSections>
<!-- For more information on Entity Framework configuration, visit http://go.microsoft.com/fwlink/?LinkID=237468 -->
<section name="entityFramework" type="System.Data.Entity.Internal.ConfigFile.EntityFrameworkSection, EntityFramework, Version=6.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" requirePermission="false" />
<section name="episerver" type="EPiServer.Configuration.EPiServerSection, EPiServer.Configuration" />
<section name="episerver.framework" type="EPiServer.Framework.Configuration.EPiServerFrameworkSection, EPiServer.Framework" restartOnExternalChanges="true" />
<section name="episerver.baseLibrary" allowDefinition="MachineToApplication" allowLocation="false" type="EPiServer.BaseLibrary.ConfigurationHandler,EPiServer.BaseLibrary" />
<section name="episerver.shell" type="EPiServer.Shell.Configuration.EPiServerShellSection, EPiServer.Shell" />
<section name="episerver.search" type="EPiServer.Search.Configuration.SearchSection, EPiServer.ApplicationModules" />
<section name="episerver.packaging" type="EPiServer.Packaging.Configuration.EPiServerPackagingSection, EPiServer.Packaging" />
</configSections>
<appSettings>
<add key="webpages:Version" value="3.0.0.0" />
<add key="webpages:Enabled" value="false" />
<add key="PreserveLoginUrl" value="true" />
<add key="ClientValidationEnabled" value="true" />
<add key="UnobtrusiveJavaScriptEnabled" value="true" />
<add key="ValidationSettings:UnobtrusiveValidationMode" value="None" />
<add key="aspnet:UseTaskFriendlySynchronizationContext" value="true" />
</appSettings>
<system.web>
<httpRuntime targetFramework="4.5.2" requestValidationMode="2.0" />
<compilation debug="true" targetFramework="4.5.2" optimizeCompilations="true" />
<pages validateRequest="false" enableEventValidation="true" pageParserFilterType="System.Web.Mvc.ViewTypeParserFilter, System.Web.Mvc, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35" enableViewState="false">
<namespaces>
<add namespace="System.Web.Helpers" />
<add namespace="System.Web.Mvc" />
<add namespace="System.Web.Mvc.Ajax" />
<add namespace="System.Web.Mvc.Html" />
<add namespace="System.Web.Routing" />
<add namespace="System.Web.WebPages" />
<add namespace="EPiServer.Shell.Web.Mvc.Html" />
<add namespace="EPiServer.Framework.Web.Mvc.Html" />
</namespaces>
<controls>
<add tagPrefix="EPiServer" namespace="EPiServer.Web.WebControls" assembly="EPiServer" />
<add tagPrefix="EPiServer" namespace="EPiServer.Web.WebControls" assembly="EPiServer.Web.WebControls" />
<add tagPrefix="XForms" namespace="EPiServer.XForms.WebControls" assembly="EPiServer.XForms" />
<add tagPrefix="EPiServer" namespace="EPiServer.Framework.Web.WebControls" assembly="EPiServer.Framework" />
</controls>
</pages>
<globalization culture="en-US" uiCulture="en" requestEncoding="utf-8" responseEncoding="utf-8" resourceProviderFactoryType="EPiServer.Framework.Localization.LocalizationServiceResourceProviderFactory, EPiServer.Framework" />
<caching>
<outputCacheSettings>
<outputCacheProfiles>
<add name="ClientResourceCache" enabled="true" duration="3600" varyByParam="*" varyByContentEncoding="gzip;deflate" />
</outputCacheProfiles>
</outputCacheSettings>
</caching>
<authentication mode="Forms">
<forms name=".EPiServerLogin" loginUrl="Util/login.aspx" timeout="120" defaultUrl="~/" />
</authentication>
<profile defaultProvider="DefaultProfileProvider">
<properties>
<add name="Address" type="System.String" />
<add name="ZipCode" type="System.String" />
<add name="Locality" type="System.String" />
<add name="Email" type="System.String" />
<add name="FirstName" type="System.String" />
<add name="LastName" type="System.String" />
<add name="Language" type="System.String" />
<add name="Country" type="System.String" />
<add name="Company" type="System.String" />
<add name="Title" type="System.String" />
<add name="CustomExplorerTreePanel" type="System.String" />
<add name="FileManagerFavourites" type="System.Collections.Generic.List`1[System.String]" />
<add name="EditTreeSettings" type="EPiServer.Personalization.GuiSettings, EPiServer" />
<add name="ClientToolsActivationKey" type="System.String" />
<add name="FrameworkName" type="System.String" />
</properties>
<providers>
<add name="DefaultProfileProvider" type="System.Web.Providers.DefaultProfileProvider, System.Web.Providers, Version=2.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" connectionStringName="EPiServerDB" applicationName="/" />
</providers>
</profile>
<membership defaultProvider="MultiplexingMembershipProvider" userIsOnlineTimeWindow="10" hashAlgorithmType="HMACSHA512">
<providers>
<clear />
<add name="MultiplexingMembershipProvider" type="EPiServer.Security.MultiplexingMembershipProvider, EPiServer.Framework" provider1="SqlServerMembershipProvider" provider2="WindowsMembershipProvider" />
<add name="WindowsMembershipProvider" type="EPiServer.Security.WindowsMembershipProvider, EPiServer" deletePrefix="BUILTIN\" searchByEmail="true" />
<add name="SqlServerMembershipProvider" type="System.Web.Providers.DefaultMembershipProvider, System.Web.Providers, Version=2.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" connectionStringName="EPiServerDB" enablePasswordRetrieval="false" enablePasswordReset="true" requiresQuestionAndAnswer="false" requiresUniqueEmail="false" maxInvalidPasswordAttempts="5" minRequiredPasswordLength="6" minRequiredNonalphanumericCharacters="0" passwordAttemptWindow="10" applicationName="/" />
</providers>
</membership>
<roleManager enabled="true" defaultProvider="MultiplexingRoleProvider" cacheRolesInCookie="true">
<providers>
<clear />
<add name="MultiplexingRoleProvider" type="EPiServer.Security.MultiplexingRoleProvider, EPiServer.Framework" provider1="SqlServerRoleProvider" provider2="WindowsRoleProvider" providerMap1="SqlServerMembershipProvider" providerMap2="WindowsMembershipProvider" />
<add name="WindowsRoleProvider" applicationName="/" type="EPiServer.Security.WindowsRoleProvider, EPiServer" />
<add name="SqlServerRoleProvider" type="System.Web.Providers.DefaultRoleProvider, System.Web.Providers, Version=2.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" connectionStringName="EPiServerDB" applicationName="/" />
</providers>
</roleManager>
</system.web>
<system.webServer>
<validation validateIntegratedModeConfiguration="false" />
<modules runAllManagedModulesForAllRequests="true">
<add name="InitializationModule" type="EPiServer.Framework.Initialization.InitializationModule, EPiServer.Framework" preCondition="managedHandler" />
<add name="UrlRewriteModule" type="EPiServer.Web.RoutingUrlRewriteModule, EPiServer" preCondition="managedHandler" />
<add name="ShellRoutingModule" type="EPiServer.Shell.Web.Routing.ShellRoutingModule, EPiServer.Shell" />
</modules>
<handlers>
<remove name="ExtensionlessUrlHandler-ISAPI-4.0_32bit" />
<remove name="ExtensionlessUrlHandler-ISAPI-4.0_64bit" />
<remove name="ExtensionlessUrlHandler-Integrated-4.0" />
<add name="ExtensionlessUrlHandler-ISAPI-4.0_32bit" path="*." verb="GET,HEAD,POST,DEBUG,PUT,DELETE,PATCH,OPTIONS" modules="IsapiModule" scriptProcessor="%windir%\Microsoft.NET\Framework\v4.0.30319\aspnet_isapi.dll" preCondition="classicMode,runtimeVersionv4.0,bitness32" responseBufferLimit="0" />
<add name="ExtensionlessUrlHandler-ISAPI-4.0_64bit" path="*." verb="GET,HEAD,POST,DEBUG,PUT,DELETE,PATCH,OPTIONS" modules="IsapiModule" scriptProcessor="%windir%\Microsoft.NET\Framework64\v4.0.30319\aspnet_isapi.dll" preCondition="classicMode,runtimeVersionv4.0,bitness64" responseBufferLimit="0" />
<add name="ExtensionlessUrlHandler-Integrated-4.0" path="*." verb="GET,HEAD,POST,DEBUG,PUT,DELETE,PATCH,OPTIONS" type="System.Web.Handlers.TransferRequestHandler" preCondition="integratedMode,runtimeVersionv4.0" />
<add name="UrlRoutingHandler" preCondition="integratedMode" verb="*" path="UrlRouting.axd" type="System.Web.HttpForbiddenHandler, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
</handlers>
<staticContent>
<clientCache cacheControlMode="UseMaxAge" cacheControlMaxAge="1.00:00:00" />
</staticContent>
<caching>
<profiles>
<add extension=".gif" policy="DontCache" kernelCachePolicy="CacheUntilChange" duration="0.00:01:00" location="Any" />
<add extension=".png" policy="DontCache" kernelCachePolicy="CacheUntilChange" duration="0.00:01:00" location="Any" />
<add extension=".js" policy="DontCache" kernelCachePolicy="CacheUntilChange" duration="0.00:01:00" location="Any" />
<add extension=".css" policy="DontCache" kernelCachePolicy="CacheUntilChange" duration="0.00:01:00" location="Any" />
<add extension=".jpg" policy="DontCache" kernelCachePolicy="CacheUntilChange" duration="0.00:01:00" location="Any" />
<add extension=".jpeg" policy="DontCache" kernelCachePolicy="CacheUntilChange" duration="0.00:01:00" location="Any" />
</profiles>
</caching>
</system.webServer>
<entityFramework>
<defaultConnectionFactory type="System.Data.Entity.Infrastructure.SqlConnectionFactory, EntityFramework" />
<providers>
<provider invariantName="System.Data.SqlClient" type="System.Data.Entity.SqlServer.SqlProviderServices, EntityFramework.SqlServer" />
</providers>
</entityFramework>
<runtime>
<assemblyBinding xmlns="urn:schemas-microsoft-com:asm.v1">
<dependentAssembly>
<assemblyIdentity name="System.Web.Helpers" publicKeyToken="31bf3856ad364e35" />
<bindingRedirect oldVersion="1.0.0.0-3.0.0.0" newVersion="3.0.0.0" />
</dependentAssembly>
<dependentAssembly>
<assemblyIdentity name="System.Web.WebPages" publicKeyToken="31bf3856ad364e35" />
<bindingRedirect oldVersion="0.0.0.0-3.0.0.0" newVersion="3.0.0.0" />
<dependentAssembly>
<assemblyIdentity name="System.Web.Mvc" publicKeyToken="31bf3856ad364e35" />
<bindingRedirect oldVersion="0.0.0.0-5.2.3.0" newVersion="5.2.3.0" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.ApplicationModules" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-9.7.3.0" newVersion="9.7.3.0" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Data.Cache" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Data" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Events" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Framework" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Licensing" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Shell" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Configuration" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Enterprise" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.ImageLibrary" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.LinkAnalyzer" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Web.WebControls" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.XForms" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<probing privatePath="modulesbin" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Cms.Shell.UI" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-9.4.3.0" newVersion="9.4.3.0" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Shell.UI" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.UI" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="System.Web.Razor" publicKeyToken="31bf3856ad364e35" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Packaging.CmdAPI" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-1.0.0.0" newVersion="1.0.0.0" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Packaging" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-3.2.3.0" newVersion="3.2.3.0" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Logging.Log4Net" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-1.1.0.0" newVersion="1.1.0.0" />
<dependentAssembly>
<assemblyIdentity name="log4net" publicKeyToken="1b44e1d426115821" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-1.2.10.0" newVersion="1.2.10.0" />
<dependentAssembly>
<assemblyIdentity name="Castle.DynamicProxy" publicKeyToken="407dd0808d44fbdc" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-1.1.5.0" newVersion="1.1.5.0" />
<dependentAssembly>
<assemblyIdentity name="DotNetOpenAuth" publicKeyToken="2780ccd10d57b246" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-4.0.0.0" newVersion="4.0.0.0" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Common.Cache" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-7.5.446.0" newVersion="7.5.446.0" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Common.ComponentArt.Web.UI" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-2008.2.1204.35" newVersion="2008.2.1204.35" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Common.Configuration" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Common.Criteria" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Common.Data" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Common.EventCounter" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Common.Framework" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Common.Framework.Exceptions" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Common.Framework.Impl" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Common.Security" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Common.Web.Authorization" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Common.Web.Authorization.Multiplexing" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Common.Web" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="Iesi.Collections" publicKeyToken="aa95f207798dfdb4" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-1.0.0.3" newVersion="1.0.0.3" />
<dependentAssembly>
<assemblyIdentity name="NHibernate" publicKeyToken="aa95f207798dfdb4" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-1.2.0.4000" newVersion="1.2.0.4000" />
<dependentAssembly>
<assemblyIdentity name="ComponentArt.Charting.WebChart" publicKeyToken="9bc9f846553156bb" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-2008.1.1346.35" newVersion="2008.1.1346.35" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Mail.Configuration" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-8.0.0.33" newVersion="8.0.0.33" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Mail.Core" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Mail.Core.Web" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Mail.Sources.Internal" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="RadEditor.Net2" publicKeyToken="852c9eb6525c1b53" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-7.3.2.0" newVersion="7.3.2.0" />
<dependentAssembly>
<assemblyIdentity name="SMTP.Net" publicKeyToken="986a9aa31056680b" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-3.0.1.2" newVersion="3.0.1.2" />
</assemblyBinding>
</runtime>
<episerver>
<applicationSettings httpCacheability="Public" pageValidateTemplate="false" uiShowGlobalizationUserInterface="true" uiUrl="~/EPiServer/CMS/" urlRebaseKind="ToRootRelative" />
</episerver>
<episerver.framework>
<appData basePath="App_Data" />
<scanAssembly forceBinFolderScan="true" />
<virtualRoles addClaims="true">
<providers>
<add name="Administrators" type="EPiServer.Security.WindowsAdministratorsRole, EPiServer.Framework" />
<add name="Everyone" type="EPiServer.Security.EveryoneRole, EPiServer.Framework" />
<add name="Authenticated" type="EPiServer.Security.AuthenticatedRole, EPiServer.Framework" />
<add name="Anonymous" type="EPiServer.Security.AnonymousRole, EPiServer.Framework" />
<add name="CmsAdmins" type="EPiServer.Security.MappedRole, EPiServer.Framework" roles="WebAdmins, Administrators" mode="Any" />
<add name="CmsEditors" type="EPiServer.Security.MappedRole, EPiServer.Framework" roles="WebEditors" mode="Any" />
<add name="Creator" type="EPiServer.Security.CreatorRole, EPiServer" />
<add name="PackagingAdmins" type="EPiServer.Security.MappedRole, EPiServer.Framework" roles="WebAdmins, Administrators" mode="Any" />
</providers>
</virtualRoles>
<virtualPathProviders>
<clear />
<add name="ProtectedModules" virtualPath="~/EPiServer/" physicalPath="Modules\_Protected" type="EPiServer.Web.Hosting.VirtualPathNonUnifiedProvider, EPiServer.Framework" />
</virtualPathProviders>
<geolocation defaultProvider="maxmind">
<providers>
<add name="maxmind" type="EPiServer.Personalization.Providers.MaxMind.GeolocationProvider, EPiServer.ApplicationModules" databaseFileName="App_Data\GeoLiteCity.dat" />
</providers>
</geolocation>
</episerver.framework>
<episerver.shell>
<publicModules rootPath="~/modules/" autoDiscovery="Modules" />
<protectedModules rootPath="~/EPiServer/">
<add name="Shell" />
<add name="CMS" />
<add name="EPiServer.Packaging.UI" />
</protectedModules>
</episerver.shell>
<location path="Modules/_Protected">
<system.webServer>
<handlers>
<clear />
<add name="BlockDirectAccessToProtectedModules" path="*" verb="*" preCondition="integratedMode" type="System.Web.HttpNotFoundHandler" />
</handlers>
</system.webServer>
</location>
<location path="EPiServer">
<system.web>
<httpRuntime maxRequestLength="1000000" requestValidationMode="2.0" />
<pages enableEventValidation="true" enableViewState="true" enableSessionState="true" enableViewStateMac="true">
<controls>
<add tagPrefix="EPiServerUI" namespace="EPiServer.UI.WebControls" assembly="EPiServer.UI" />
<add tagPrefix="EPiServerScript" namespace="EPiServer.ClientScript.WebControls" assembly="EPiServer" />
<add tagPrefix="EPiServerScript" namespace="EPiServer.UI.ClientScript.WebControls" assembly="EPiServer.UI" />
</controls>
</pages>
<globalization requestEncoding="utf-8" responseEncoding="utf-8" />
<authorization>
<allow roles="WebEditors, WebAdmins, Administrators" />
<deny users="*" />
</authorization>
</system.web>
<system.webServer>
<handlers>
<clear />
<add name="AssemblyResourceLoader-Integrated-4.0" path="WebResource.axd" verb="GET,DEBUG" type="System.Web.Handlers.AssemblyResourceLoader" preCondition="integratedMode,runtimeVersionv4.0" />
<add name="PageHandlerFactory-Integrated-4.0" path="*.aspx" verb="GET,HEAD,POST,DEBUG" type="System.Web.UI.PageHandlerFactory" preCondition="integratedMode,runtimeVersionv4.0" />
<add name="SimpleHandlerFactory-Integrated-4.0" path="*.ashx" verb="GET,HEAD,POST,DEBUG" type="System.Web.UI.SimpleHandlerFactory" preCondition="integratedMode,runtimeVersionv4.0" />
<add name="WebServiceHandlerFactory-Integrated-4.0" path="*.asmx" verb="GET,HEAD,POST,DEBUG" type="System.Web.Script.Services.ScriptHandlerFactory, System.Web.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" preCondition="integratedMode,runtimeVersionv4.0" />
<add name="svc-Integrated-4.0" path="*.svc" verb="*" type="System.ServiceModel.Activation.ServiceHttpHandlerFactory, System.ServiceModel.Activation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" preCondition="integratedMode,runtimeVersionv4.0" />
<add name="wildcard" path="*" verb="*" type="EPiServer.Web.StaticFileHandler, EPiServer.Framework" />
</handlers>
</system.webServer>
</location>
<location path="EPiServer/CMS/admin">
<system.web>
<authorization>
<allow roles="WebAdmins, Administrators" />
<deny users="*" />
</authorization>
</system.web>
</location>
<location path="util">
<system.web>
<pages enableEventValidation="true">
<controls>
</controls>
</pages>
</system.web>
<system.webServer>
<handlers>
<clear />
</handlers>
</system.webServer>
</location>
<location path="modulesbin">
<system.web>
<authorization>
<deny users="*" />
</authorization>
</system.web>
</location>
<episerver.search active="false">
<namedIndexingServices defaultService="serviceName">
<services>
<add name="serviceName" baseUri="Please insert the indexing search service endpoint here if the episerver.search is active. If local service is used pattern is http://sitehost/IndexingService/IndexingService.svc" accessKey="local" />
</services>
</namedIndexingServices>
<searchResultFilter defaultInclude="true">
<providers />
</searchResultFilter>
</episerver.search>
<system.serviceModel>
<serviceHostingEnvironment multipleSiteBindingsEnabled="true" />
</system.serviceModel>
<episerver.packaging protectedVirtualPath="~/EPiServer/" protectedPath="modules/_Protected" publicVirtualPath="~/modules/" publicPath="modules" installationMode="Code" />
<connectionStrings>
<add name="EPiServerDB" connectionString="Data Source=.\SQLEXPRESS;AttachDbFilename=|DataDirectory|EPiServerDB_8930457d.mdf;Initial Catalog=EPiServerDB_8930457d;Connection Timeout=60;Integrated Security=True;MultipleActiveResultSets=True" providerName="System.Data.SqlClient" />
</connectionStrings>
</configuration>
#149290
May 27, 2016 16:39
