Weird problem in Manage Recipients
I've noticed a weird thing in the Manage Recipients section. If I use the headlines to order the list of recipientscontainers it all seems to work ok but if I after sorting clicks for exampel to show the recipients in the list I get the list from the list that was in that position on the unsorted list.
To clarify this a little more, say I have to listA & listB. Unsorted listA comes first. If I click to sort by date so that listB is first and then clicks to export listB recipients I would get listA recipients instead, same goes for invalid records although hovering this icons gives me the right amount but then the file contains a diffrent amount of invalid records (listA)
Is this an error that someone can reproduce or has experienced?
#31119
Jul 03, 2009 12:00
btw using EpiServerMail 4.4, database migrated from EPiServerMail 4.3
and just discovered that paging in the list produces the same thing
#31120
Edited, Jul 03, 2009 12:01
What you describe sounds like really strange behaviour. Provided that it's reproducible it would seem to be a bug.
Thank you for reporting this, we are looking into it!
You may also want to open a case with Support directly for matters like this,
http://world.episerver.com/en/Support/Register-Support-Incident/
#31390
Edited, Jul 27, 2009 9:33
This issue has been confirmed, the fix will be part of the next update.
#31459
Jul 31, 2009 11:21
Hi Hakan,
Do you have any updates on this issue or at least some approximate date when you will be releasing the next version of EpiMail?
Thank you.
#31748
Aug 11, 2009 10:58
I do not have any solid date at this point, but I do believe a fix will be made available as part of a hotfix for 4.4 SP1 in the relatively near future.
#31873
Aug 13, 2009 11:40
Just a quick update, a fix for this was included in Mail 4.4 SP1 Hotfix 1 which was released some time ago.
 http://world.episerver.com/Download/Items/Hotfixes/EPiServer-Mail/Hotfix-1---EPiServer-Mail-44-SP1/
#32876
Sep 22, 2009 14:12
Hi Hakan,
We have already updated to that version and it works fine. Thank you for the update though.
#32899
Sep 23, 2009 9:29
