In CMS Edit mode, choose your language in the CMS page tree (under the "Structure" tab).
Then, use the functionality under the "EPiServer Mail" tab of the page you wish to send.
Thanks Joakim, it seems to work if I change the language as you write and selecting the mail-tab on a page.
However it doesn't work if I want to send a page via the "Main" Mail-tab, the one on the same level as the Structure-tab. Hope you understand which one I mean.
If I go through the steps here I can only select pages with the default langauge, in this case: Swedish.
Can you verfy this if you have Mail installed?
Hi Fredrik, happy to hear that you got it to work.
Accessing other language versions of a page is currently only supported from the pages own "EPiServer Mail" tab, like you just did.
I found this page http://world.episerver.com/Articles/Items/EPiServer-Mail-44-Released/ which states:
"The possibility to select language version when sending a CMS page".
Currently running 4.4 SP1 from an upgraded 4.3 and I can't find where to select the language, am I missing something obvious or do I have to enable this functionality somewhere?
