Composer global blocks cache update issues ?
Hi - Is anyone aware of any issues where changes in composer global blocks does not successfully clear cache or raise cache events in EPiServer load-balanced environment . I am currently facing this issues where everything else goes instantly including any changes with composer blocks whereas composer global blocks does not seem to update cache for a long period of time. LB is set over TCP / IP. [EPiServer 6 R2]
Cheers
#68063
Mar 15, 2013 13:12
I seem to be having the same issue. Anyone got a solution or is it a confirmed bug?
#79989
Jan 13, 2014 11:57
