add/replace existing Access rights Composer block
I want to add an AD User Group to all existing Composer Block
Is it possible to add or even replace existing Access rights on multiple Composer Block,
without having to manually edit every Composer Block? It would spare a lot of time!
I can, as far as I understand, set default access rights in "Admin GUI /Tools/EPiServer Composer/Block Types Choose Block, for example Content and Access", but it will not change access rights for existing blocks.
/Paul
#68017
Mar 14, 2013 16:55
Have you tried setting access rights on extension data container - that should work and change access rights in existing components
#68064
Mar 15, 2013 13:14
Thank you very much!
That made it!
Paul
#68216
Mar 19, 2013 10:15
Hi guys
I know that it is an old post, but will try my luck anyhow.
Where do I exactly change the rights for Extension Data Container?
Br
Miroslav
#139962
Oct 12, 2015 12:21
