Problems installing 4R2 on CMS 6R2
We have a site which was 5R2. Upgraded it to 6 and then 6R2 last month. Now, whenever I try installing Composer 4R2 I get the following error. However, If I create a new 6 R2 site and then install 4 R2 it installs fine.
---- INSTALLER LOG START ----
Started a transacted install
Copied Dropit.ComponentArt.Web.UI.dll
Copied Dropit.Extension.dll
Copied Dropit.Extension.UI.dll
Copied CompleteImportingScript.sql
Copied ajax10.config
Copied ajax35.config
Copied dropit.extension.config
Copied extension.episerverdata
Copied extension.upgrade.episerverdata
Copied GuidTranslation.sql
Copied PersonalizationBlockData.xml
Copied update.config
Copied web.config.xmlupdate
Copied web.config.xmlupdate.iis6
Copied web.config.xmlupdate.iis7
Copied AccessControl.ascx
Copied ActionButtonControl.ascx
Copied AddGroupDialog.ascx
Copied ConfirmDialog.ascx
Copied ExtensionCategories.ascx
Copied ExtensionCategoryAdd.ascx
Copied ExtensionSettings.ascx
Copied ExtensionTemplateList.ascx
Copied FunctionPropertyAdd.ascx
Copied FunctionTypeAccess.ascx
Copied FunctionTypeAdd.ascx
Copied FunctionTypeAvailableContentArea.ascx
Copied FunctionTypeInformation.ascx
Copied FunctionTypeList.ascx
Copied FunctionTypeProperties.ascx
Copied FunctionTypeRules.ascx
Copied Install.ascx
Copied PageTypeAccess.ascx
Copied PageTypeAdd.ascx
Copied PageTypeInformation.ascx
Copied PageTypeList.ascx
Copied PageTypeProperties.ascx
Copied PageTypeRules.ascx
Copied SettingAccessPersonalizationFunction.ascx
Copied SettingDefaultAccessFunctionType.ascx
Copied SettingDefaultAccessPageType.ascx
Copied ExtensionEditPageType.aspx
Copied ExtensionManager.aspx
Copied Install.aspx
Copied MembershipAccessLevel.aspx
Copied PersonalizationContainerPropertyControl.ascx
Copied PersonalizationFunction.ascx
Copied VisitorGroupList.aspx
Copied AccessRightsControl.ascx
Copied EditPageControl.ascx
Copied EditTool.ascx
Copied ExtensionDialog.ascx
Copied ExtensionToolButtonControl.ascx
Copied ExtensionXFormData.ascx
Copied FunctionBar.ascx
Copied GlobalBlockDialog.ascx
Copied GlobalFunctionReferences.ascx
Copied MessageBox.ascx
Copied PagesUsingGlobalFunction.ascx
Copied UsingInPages.ascx
Copied VersionList.ascx
Copied ClipboardHandler.ashx
Copied CreateContentFunction.aspx
Copied DeleteContentFunction.aspx
Copied FavoriteHandler.ashx
Copied LanguageBranchHandler.ashx
Copied LoadFunctionBar.aspx
Copied LoadPageStruct.aspx
Copied ReloadContentFunction.aspx
Copied SaveAsGlobalFunction.aspx
Copied SaveExtensionPage.aspx
Copied TestHarness.ashx
Copied UpdateFunctionBar.aspx
Copied VersionListHandler.ashx
Copied FunctionPickerReport.aspx
Copied blank.htm
Copied EditGlobalFunction.aspx
Copied ExtensionData.aspx
Copied ExtensionNewPage.aspx
Copied ExtensionShadow.aspx
Copied ExtensionWorkspace.aspx
Copied FunctionAccessRights.aspx
Copied FunctionPicker.aspx
Copied GlobalFunctionPropertyEditor.aspx
Copied PagePropertyEditor.aspx
Copied PropertyEditor.aspx
Copied TemplateAccessRights.aspx
Copied TemplatePropertyEditor.aspx
Copied hand_closed.cur
Copied hand_open.cur
Copied Cookies.js
Copied Cookies.min.js
Copied Diagnostics.js
Copied Extension.CallbackClipboard.js
Copied Extension.CallbackContentFunction.js
Copied Extension.CallbackExtensionPage.js
Copied Extension.CallbackFavorite.js
Copied Extension.CallbackFunctionBar.js
Copied Extension.CallbackLanguageBranch.js
Copied Extension.CallbackLanguageBranch.min.js
Copied Extension.CallbackObject.js
Copied Extension.CallbackVersionList.js
Copied Extension.CallbackVersionList.min.js
Copied Extension.ContentArea.js
Copied Extension.ContentFunction.js
Copied Extension.ExtensionClient.js
Copied Extension.js
Copied Extension.LanguageManager.js
Copied Extension.Page.js
Copied Extension.Rule.js
Copied Extension.ToolButtonControl.js
Copied Extension.UI.AddGroupDialog.js
Copied Extension.UI.BaseItem.js
Copied Extension.UI.BaseModalDialog.js
Copied Extension.UI.BasePanel.js
Copied Extension.UI.BaseSubPanel.js
Copied Extension.UI.CategoryItem.js
Copied Extension.UI.CategoryPanel.js
Copied Extension.UI.ClipboardItem.js
Copied Extension.UI.ClipboardPanel.js
Copied Extension.UI.ConfirmDialog.js
Copied Extension.UI.ContentFunctionMenu.js
Copied Extension.UI.ContextMenu.js
Copied Extension.UI.ExtensionDialog.js
Copied Extension.UI.FunctionBar.js
Copied Extension.UI.GlobalBlockDialog.js
Copied Extension.UI.LanguageBranch.js
Copied Extension.UI.LanguageBranch.min.js
Copied Extension.UI.MessageBox.js
Copied Extension.UI.PreviewMode.js
Copied Extension.UI.PropertiesDialog.js
Copied Extension.UI.RecycleBinPanel.js
Copied Extension.UI.SubCategoryPanel.js
Copied Extension.UI.TemplateItem.js
Copied Extension.UI.VersionList.js
Copied Extension.UI.VersionList.min.js
Copied ExtensionMembershipAccessLevel.js
Copied JQ.js
Copied JQ.min.js
Copied jquery.DropShadow.js
Copied jquery.DropShadow.min.js
Copied jquery.OffsetFix.js
Copied jquery.PersonalizationCustomProperty.js
Copied jquery.PersonalizationCustomProperty.min.js
Copied JSFx.js
Copied json2.js
Copied json2.min.js
Copied Program.js
Copied Program.min.js
Copied prototype.js
Copied prototype.min.js
Copied Utils.js
Copied Utils.min.js
Copied x3.min.js
Copied ExtensionAdminUI.master
Copied ExtensionUI.master
Copied common.css
Copied dialog.css
Copied ext3core.css
Copied function.css
Copied functionbar.css
Copied functionmenu.css
Copied menustyle.css
Copied multipage.css
Copied PersonalizationCustomProperty.css
Copied PersonalizationCustomProperty.min.css
Copied sortablegrid.css
Copied tabstyle.css
Copied toolbar.css
Copied toolbutton.css
Copied treestyle.css
Copied x3.min.css
Copied blank.htm
Copied ExtensionDynamicContentControl.ascx
Copied ExtensionPageControl.ascx
Copied ResourceHandler.ashx
Copied module.config
Copied Dropit.Extension_DA.xml
Copied Dropit.Extension_EN.xml
Copied Dropit.Extension_FI.xml
Copied Dropit.Extension_NL.xml
Copied Dropit.Extension_NO.xml
Copied Dropit.Extension_SV.xml
Copied newtext_Dropit.Extension.xml
Copied newtext_Dropit.Extension_SENT.xml
Copied Install Composer.metadata
Copied Upgrade Composer.metadata
An error has occured and the transaction will be rolled back
Rolledback
An unhandled error has occured:
When executing
At C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\Composer 4.1\
Install Composer.ps1:138 char:20
+ Add-EPiServerData <<<<  $episerverDataFile $selectedWebApplication.Physical
Path $selectedWebApplication.ApplicationName -updateStartPageAttribute
False
Get-EPiIsBulkInstalling
At C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\Composer 4.1\Install Composer.ps1:138 char:20
+ Add-EPiServerData <<<<  $episerverDataFile $selectedWebApplication.PhysicalPath $selectedWebApplication.ApplicationName -updateStartPageAttribute
EPiServer.PlugIn.PlugInException
   at EPiServer.PlugIn.AssemblyTypeInfo.GetTypes()
   at EPiServer.PlugIn.AssemblyTypeInfo.ScanAssembly()
   at EPiServer.PlugIn.PlugInLocator.get_Assemblies()
   at EPiServer.PlugIn.PlugInLocator.FindPlugInAttributes()
   at EPiServer.PlugIn.PlugInRuntime.InitRunTimePlugins(Boolean reset)
   at EPiServer.PlugIn.PlugInRuntime.Start(Boolean reset)
   at EPiServer.Web.InitializationModule.InitializePluginRuntime(Boolean reset)
   at EPiServer.Install.CMS.Common.EPiServerCMSWrapper.InitalizeEPiServer(String webConfigPath)
   at EPiServer.Install.CMS.Common.EPiServerCMSWrapper.Initialize(String destinationPath, String virtualDirectory)
   at EPiServer.Install.Common.AppDomains.RunInAppDomainInstaller.Install(IDictionary stateSaver)
   at EPiServer.Install.InstallationManager.Install(Installer installer)
   at EPiServer.Install.CMS.Modules.ModulesInstallationManager.ImportData(InstallationManager installationManager, String destinationDirectory, String virtualDirectory, String importSource, DatabaseDestination destination, Boolean updateStartPageAttribute, TimeSpan transactionTimeout)
   at EPiServer.Install.CMS.Modules.CmdLets.AddEPiServerData.ProcessRecord()
   at System.Management.Automation.Cmdlet.DoProcessRecord()
   at System.Management.Automation.CommandProcessor.ProcessRecord()
---- INSTALLER LOG END ----
#58321
Apr 19, 2012 11:38
Did you find a solution to this problem?
#91067
Sep 25, 2014 7:32
