Hi Stephen
From which version of Composer did you run the upgrading? Please re-check the following document, specially if your previous version of Composer was 3.2.6,
Regards
Hieu Doan
Hi Doan,
The previous version of composer(dropit.extension.dll) was 4.0.0.70. I tried the link you provided above, but it seems I do not have access to the document.
Kind regards,
Stephen Albert
Same problem here. Can you post an answer on how did you solve the issue?
I experienced the same error when the EPiServer.ComposerSampleTemplates.dll assembly was not present in the bin folder.
I'm currently installing a new instance of Composer on a new CMS 6 R2 site (no upgrade).
Regards,
Vibeke
I am getting the exact same error as above after upgrading Composer.
The site didn't use ComposerSampleTemplates.dll before upgrade and it doesn't fix issue if I place it in bin folder as described above.
Anyone got any ideas as to the cause of this?
I would imagine this is happening because one of the dependencies - didn't get added to the solution during the upgrade. This is likely to either be a property definition or a pagetype (composer definition). Composer 4.1 adds a custom property called Personalization Container Property and also a new Function (PageType) definition called [ExtensionSys] Personalization Container
Can you see this property and PageType listed in the in Admin mode?
If not I would check the following:
1) Are the Composer Libraries correctly included in the bin and are they the correct version
DropIt.Extension.dll - version 4.1.0.142
DropIt.Extension.Ui.dll - version 4.1.0.142
One of these libraries will contain the definition for new page custom properties, which should be added on initialization
2) Have the additional function types been set up. I've written a blog about one page type that I found was missing (which was my own fault during upgrade). You can import this via the xml file I've included on my blog - though this probably will fail if the new custom property defintion doesn't exist.
I have this exact same problem, but it's been Composer 4 R2 from the beginning. The exception message isn't too helpful. ;)
A little more information - we've seen these type of exceptions thrown when the EPiServer database contains records of custom properties from assemblies that are no longer in the solution.
I'm not sure exactly why the upgrade process uncovers these - but we managed to help fix one issue like this by purging the database of obsolete custom property references.
Mark, you're my hero. I could seriously hug you right now - but not in a weird way or anything. :)
Ok, so here's how to reproduce it:
Thanks a LOT for pointing me in the right direction!
Awesome - glad that helped. I can't take the credit for that discovery though. Gareth Kelly who posted earlier in this thread was the 'hero' who wrestled with the issue to find that solution.
Looks like this may be a genuine bug, as the core CMS product doesn't display similar behaviour.
I had the same issue and got 500 error when clicked Episerver Composer link in the Admin mode.
That was due to some redundant properties in the Custom Property Types whcih have been used by some of our Composer controls.
So I needed to remove the redundant properties which were using a non existing assembly. And the error was resolved.
I will add the full solution to my blog at http://www.objectmasters.com/blog/ .
Thank you all.
just got the same issue here.
whats the easies way to delete these obelete custome properties
we have here more than 300 plugins here :(
I upgraded composer to episerver 4.0 R2. When I go to admin mode "EPiServer Composer" I get the following error"
Object reference not set to an instance of an object.
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
Stack Trace:
Dropit.Extension.UI.Admin.Controls.FunctionTypeList.<DataBind>b__1(PageDefinition pageDef) +41
System.Linq.Enumerable.Any(IEnumerable`1 source, Func`2 predicate) +166
Dropit.Extension.UI.Admin.Controls.FunctionTypeList.<DataBind>b__0(ContentFunctionType cf) +142
System.Collections.Generic.List`1.RemoveAll(Predicate`1 match) +79
Dropit.Extension.UI.Admin.Controls.FunctionTypeList.DataBind() +583
Dropit.Extension.UI.Admin.Controls.FunctionTypeList.Page_Load(Object sender, EventArgs e) +12
System.Web.UI.Control.OnLoad(EventArgs e) +131
System.Web.UI.Control.LoadRecursive() +65
System.Web.UI.Control.LoadRecursive() +190
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2427
Version Information: Microsoft .NET Framework Version:2.0.50727.3623; ASP.NET Version:2.0.50727.3618
Could you please help me solving this issue.
Kind regards,
Stephen Albert
