Hey Danie,
Its been a while since we last spoke :-P
We actually came across a similar problem. In our case we were including a jQuery library which was conflicting with the composer one.
The problem is not jQuery itself, but rather the use of the "$" sign which is used by many javascript libraries.
Found a post here that helped me narrow down the problem. Also have a look here if you are using the jQuery library.
So if you are including jQuery somewhere in your project, you will need to do the following
Then just be sure to use "j" instead of "$" throughout the project.
Hope this helps
You can also without having to set:
We're using composer in EPiServer CMS 6. This works fine on all pages except one page because of a javascript error. The page by itself does not throw an error, but when I switch to "edit composer" mode, I get 2 javascript errors. See end of message.
It seems that composer is using Microsoft's Ajax which is causing the problem. I can't see anything wrong with the way we've setup the page as it is exactly the same as the other composer pages?
Danie
Error: a is null
Source File: http://test/ScriptResource.axd?d=ie9cioxQAV9f80NptsWUWonAatMCfEEcJtD-OTunbMe_gI0XNYMRlyrm2huc5fxMciArspHNVZCgjqKG6mj8yi6BAJP7i0RaGTwgnD9lHy0LfY1lcjKjPVYc6sheMO-If2ZZkIJ-hH-Og1s2z1-k0EFJ_IBpbDCGgLFBrg6chmw1&t=2610f696
Line: 5
Error: oConfirmDlg_oDialog is not defined
Source File: http://test/Dropit/Plugin/Extension/UI/Js/x3.min.js
Line: 1
