Composer, JavaScript Error
Im trying to add Composer to a existing project. Everything seems to work well at the server-side, but i cant drag and drop functions without getting this JS error:
draggable.isSelected is not a function
I have excluded all my code related to the project and only running the Composer Sample package, with an empty masterpage.
Any suggestions would be appreciated!
Regards,
Anton
#39463
May 17, 2010 17:20
Dear Anton
Which version of Composer and browser are you using?
Regards
Hieu Doan
#39469
May 17, 2010 22:09
Sounds like this problem, which now is solved in 3.2.6
http://world.episerver.com/Templates/Forum/Pages/Thread.aspx?id=31182&epslanguage=en
#39510
May 19, 2010 9:40
Dropit.Extension.dll > version: 3.2.5.130
Dropit.Extension.UI.dll > version  3.2.5.130
Dropit.ComponentArt.Web.UI.dll > version 2008.1.1085.35
Chrome, Firefox and IE 8
#39524
May 19, 2010 14:15
Then I'm fairly sure it's the problem I mentioned above. If you don't want to upgrade to 3.2.6 you can just replace the rico.js with the one found in the thread above (backup first ofcourse:). This solves dragging issues with firefox 3.5 and possibly other browsers.
#39525
May 19, 2010 14:19
How can I upgrade to 3.2.6?
#39526
May 19, 2010 14:20
Thanks Ulrik, will try that
#39527
May 19, 2010 14:21
If you want to upgrade. Just download the composer http://world.episerver.com/Download/Categories/Modules/EPiServer-Composer/ install and then upgrade via deployment center
#39528
May 19, 2010 14:24
Okay, I have upgraded to 3.2.6, now it works in IE 8 but no other browser.
Firebug tells me following error, when trying to save a function and the preloader just loads forever.
htmlElement.getAttribute is not a function
http://innebandy.epi5.se/Dropit/Plugin/Extension/UI/Js/Extension.ContentFunction.js
Line 205htmlElement.getAttribute is not a function "/Dropit/Plugin/Extension/UI/Js/Extension.ContentFunction.js" Line 20
this.TypeId = htmlElement.getAttribute("typeid");
Line 205
Is this normal behavior?
Regards,
Anton
#39529
May 19, 2010 15:18
