Installation fails with err msg "The application relative virtual path '~/upload/' cannot be made absolute, because the path to the application is not known"
Error log and stack trace:
Started a transacted install
Copied Dropit.ComponentArt.Web.UI.dll
Copied Dropit.Extension.dll
Copied Dropit.Extension.UI.dll
Copied about.aspx
Copied Help.aspx
Copied style.css
Copied CompleteImportingScript.sql
Copied ajax10.config
Copied ajax35.config
Copied dropit.extension.config
Copied extension.episerverdata
Copied extension.upgrade.episerverdata
Copied update.config
Copied web.config.xmlupdate
Copied web.config.xmlupdate.iis6
Copied web.config.xmlupdate.iis7
Copied AccessControl.ascx
Copied ActionButtonControl.ascx
Copied AddGroupDialog.ascx
Copied ConfirmDialog.ascx
Copied ExportData.ascx
Copied ExtensionCategories.ascx
Copied ExtensionCategoryAdd.ascx
Copied ExtensionSettings.ascx
Copied ExtensionTemplateList.ascx
Copied FunctionPropertyAdd.ascx
Copied FunctionTypeAccess.ascx
Copied FunctionTypeAdd.ascx
Copied FunctionTypeAvailableContentArea.ascx
Copied FunctionTypeInformation.ascx
Copied FunctionTypeList.ascx
Copied FunctionTypeProperties.ascx
Copied FunctionTypeRules.ascx
Copied Install.ascx
Copied PageTypeAccess.ascx
Copied PageTypeAdd.ascx
Copied PageTypeInformation.ascx
Copied PageTypeList.ascx
Copied PageTypeProperties.ascx
Copied PageTypeRules.ascx
Copied SettingDefaultAccessFunctionType.ascx
Copied SettingDefaultAccessPageType.ascx
Copied ExtensionEditPageType.aspx
Copied ExtensionManager.aspx
Copied Install.aspx
Copied MembershipAccessLevel.aspx
Copied AccessRightsControl.ascx
Copied EditPageControl.ascx
Copied EditTool.ascx
Copied ExtensionDialog.ascx
Copied ExtensionToolButtonControl.ascx
Copied ExtensionXFormData.ascx
Copied FunctionBar.ascx
Copied LanguageBranchControl.ascx
Copied MessageBox.ascx
Copied RssReader.ascx
Copied UsingInPages.ascx
Copied VersionControl.ascx
Copied VersionList.ascx
Copied ClipboardHandler.ashx
Copied CreateContentFunction.aspx
Copied DeleteContentFunction.aspx
Copied FavoriteHandler.ashx
Copied LanguageBranchHandler.ashx
Copied LoadFunctionBar.aspx
Copied LoadPageStruct.aspx
Copied ReloadContentFunction.aspx
Copied SaveAsGlobalFunction.aspx
Copied SaveExtensionPage.aspx
Copied TestHarness.ashx
Copied UpdateFunctionBar.aspx
Copied VersionListHandler.ashx
Copied blank.htm
Copied ExtensionData.aspx
Copied ExtensionNewPage.aspx
Copied ExtensionShadow.aspx
Copied ExtensionWorkspace.aspx
Copied FunctionAccessRights.aspx
Copied PagePropertyEditor.aspx
Copied PropertyEditor.aspx
Copied TemplateAccessRights.aspx
Copied TemplatePropertyEditor.aspx
Copied hand_closed.cur
Copied hand_open.cur
Copied firebug.css
Copied firebug.html
Copied firebug.js
Copied firebugx.js
Copied Cookies.js
Copied Diagnostics.js
Copied Extension.CallbackClipboard.js
Copied Extension.CallbackContentFunction.js
Copied Extension.CallbackExtensionPage.js
Copied Extension.CallbackFavorite.js
Copied Extension.CallbackFunctionBar.js
Copied Extension.CallbackLanguageBranch.js
Copied Extension.CallbackObject.js
Copied Extension.CallbackVersionList.js
Copied Extension.ContentArea.js
Copied Extension.ContentFunction.js
Copied Extension.ExtensionClient.js
Copied Extension.HistoryManager.js
Copied Extension.js
Copied Extension.LanguageManager.js
Copied Extension.Page.js
Copied Extension.Rule.js
Copied Extension.ToolButtonControl.js
Copied Extension.UI.AddGroupDialog.js
Copied Extension.UI.BaseItem.js
Copied Extension.UI.BaseModalDialog.js
Copied Extension.UI.BasePanel.js
Copied Extension.UI.CategoryItem.js
Copied Extension.UI.CategoryPanel.js
Copied Extension.UI.ClipboardItem.js
Copied Extension.UI.ClipboardPanel.js
Copied Extension.UI.ConfirmDialog.js
Copied Extension.UI.ContextMenu.js
Copied Extension.UI.ExtensionDialog.js
Copied Extension.UI.FunctionBar.js
Copied Extension.UI.LanguageBranch.js
Copied Extension.UI.MessageBox.js
Copied Extension.UI.PropertiesDialog.js
Copied Extension.UI.RecycleBinPanel.js
Copied Extension.UI.SlidingPanel.js
Copied Extension.UI.TemplateItem.js
Copied Extension.UI.VersionList.js
Copied ExtensionMembershipAccessLevel.js
Copied JSFx.js
Copied Program.js
Copied prototype.js
Copied rico.js
Copied Utils.js
Copied x3.js
Copied ExtensionUI.master
Copied common.css
Copied dialog.css
Copied ext3core.css
Copied functionbar.css
Copied menustyle.css
Copied multipage.css
Copied sortablegrid.css
Copied tabstyle.css
Copied toolbar.css
Copied toolbutton.css
Copied treestyle.css
Copied x3.css
Copied blank.htm
Copied ExtensionDynamicContentControl.ascx
Copied ExtensionPageControl.ascx
Copied ResourceHandler.ashx
Copied Dropit.Extension_EN.xml
Copied Dropit.Extension_SV.xml
Copied Install Composer.metadata
Copied Upgrade Composer.metadata
An error has occured and the transaction will be rolled back
Rolledback
An unhandled error has occured:
use the path to the application is not known.
When executing
At C:\Program Files\EPiServer\CMS\5.2.375.236\Install\Modules\Extension 3.2\Ins
tall Composer.ps1:123 char:20
+ 		Add-EPiServerData  <<<< $episerverDataFile $selectedWebApplication.Physical
Path $selectedWebApplication.ApplicationName
False
Get-EPiIsBulkInstalling
Error - System.Management.Automation.CmdletInvocationException: The application relative virtual path '~/upload/' cannot be made absolute, because the path to the application is not known. ---> System.Web.HttpException: The application relative virtual path '~/upload/' cannot be made absolute, because the path to the application is not known.
   at System.Web.VirtualPath.get_VirtualPathString()
   at System.Web.VirtualPathUtility.ToAbsolute(String virtualPath)
   at EPiServer.Web.Hosting.VirtualPathPageMappingProvider..ctor(String name, NameValueCollection configParameters)   at EPiServer.Install.InstallationManager.Install(Installer installer)
   at EPiServer.Install.CMS.Modules.ModulesInstallationManager.ImportData(InstallationManager installationManager, String destinationDirectory, String virtualDirectory, String importSource, DatabaseDestination destination, Boolean updateStartPageAttribute)
   at EPiServer.Install.CMS.Modules.CmdLets.AddEPiServerData.ProcessRecord()
   at System.Management.Automation.Cmdlet.DoProcessRecord()
   at System.Management.Automation.CommandProcessor.ProcessRecord()
   at System.Management.Automation.Internal.PipelineProcessor.SynchronousExecuteEnumerate(Object input, Hashtable errorResults, Boolean enumerate)
   at System.Management.Automation.Parser.PipelineNode.Execute(Array input, Pipe outputPipe, ArrayList& resultList)
   at System.Management.Automation.Parser.StatementListNode.Execute(Array input, Pipe outputPipe, ArrayList& resultList)
#37661
Mar 16, 2010 11:25
There is a bug that the mapping Virtual Path Providers in EPiServer.Legacy4 does not work in a non-web context (e.g. installer), this has been fixed in CMS6. The workaround for EPiServer5 is to outcomment those providers from web.config (if present) during installtion or upgrade.
#37806
Mar 19, 2010 23:29
You can try to comment out all the "upload" stuff in the web.config file before installation
#37970
Mar 25, 2010 3:46
