Some more information which may help.
The following error can be found in the log "Path /ClientBin/CartLicense.axd' was not found".
Found it. There are two references to CartLicense.axd in the web config and I was missing one of them. Finally tracked it down in the config modification files in the Install folders.
Hi! Would you care to share what the second location was? :) Thanks!
The Community Activity Gadget in the dashboard is giving me this error when loaded:
"There was an error initializing ComponentArt Web.UI for silverlight.
Please configure the web application as outlined in the QuickStart section of the documentation."
I thought it might be due to this entry in the configuration file being in the wrong location:
<add name="CartLicense" verb="*" path="CartLicense.axd" type="ComponentArt.Silverlight.Server.LicensingHandler, ComponentArt.Silverlight.Server" />
but I have confirmed it is located under /Configuration/system.webServer/handlers and I'm running on IIS7.
Anyone know what might be causing this error?
