Found the issue, I was using an unadded action. The action was created but not added the the system.
Then, the story gets removed for everyone, so I guess the best way to do this is create a new story for each user that needs to read it, so when it gets removed, it doesn't get removed for each user
Hi all,
I'm trying to make sense out of the NewsFeed system. So far I understand that Stories are based on Actions and stories are published to NewsFeeds. NewsFeeds are created for a certain user.
Now, I'm creating an Action, adding it to the system and then creating a story that I add to the system with AddStory.
Next, I have 2 users, user1 and user2. user1 created the story and is marked as the actor. I get the NewsFeed object for both users, if it does not exist yet, I create it and get it back through the NewsFeedHandler. Once I have done this, I try to add the story to the NewsFeed of both users, using NewsFeedHandler.Instance.PublishStory(story)
For both users I next fetch the NewsFeedStoryCollection through the NewsFeedHandler (NewsFeedType.NewsFeed, Status.Approved)
This does not produce the output I expect (being the 1 story I published to both NewsFeeds)
How can I do what I want to do?
Also, if I remove the story, does it remove it from both NewsFeeds? What if I want to persist the story but remove it from user2's NewsFeed?
Vincent
