ControlWrapper.aspx kills edit tree connection
Using Community 3.1 the connection between the left and right frame of edit mode is lost whenever a module in the Community tab is selected (so a reload is required before pages can be opened and edited). I suppose the ControlWrapper.aspx lacks some javascript or something that is used to keep the frames connected. Can I add it? How?
#32694
Sep 14, 2009 9:19
Yes, you can add something like this javascript (which is there in the current version):
    <script type='text/javascript'>
        function onNavigate(newPageLink)
            return -1;
        function onCommand(newCommand)
            return -1;
        function TestOfficeAddin()
            if(!document.getElementById("componentTable"))
                return;
        function onLoad()
            if(window.TestClientTools)
                TestClientTools();
            if(window.TestOfficeAddIn)
                TestOfficeAddIn();
    </script>
#32708
Sep 14, 2009 15:20
