Override Alias in IUser
Hi! I would like to override the Alias property of IUser (or User as I guess is the actual class used?). How do I manage to do this? I don't want to implement the IUser interface, since it's quite complex. Smile If I inherit User, I'm not able to just pass a DbDataReader to the base constructor. Any suggestions?
PS. I know that I have to create an EntityProvider and change the EntityProviders.config file. Wink
Thanks! Erik Lidälv
#22124
Jul 24, 2008 10:25
It is a somewhat complex task to override types in the security assembly. If possible, I would recommend against doing that and find an alternate way instead.
#22869
Aug 19, 2008 15:01
Hi! Thanks for your replay! Is it possible ta add a new Property to IUser, as described in section "3.1. Extending StarCommunity classes" in the "Netstar - StarCommunity 3.1 - A Programmer´s Guide.pdf" file?
/Erik
#22902
Aug 20, 2008 10:20
