Query with array problems
I have a forum where I want to implement a search using StarCommunity.Modules.Forum.Queries. When I want to search the topic.Text and topic.Subject for one word it works great, but when I have an array of words i cant get it to work without making more than one GetQueryResult, witch erases the possibility of using paging.
Is there any solution for this?
#21332
Jun 26, 2008 14:34
You can use the InCriterion of StringCriterion to filter on multiple values, like an SQL IN statement.
Like so:
TopicQuery tq = new TopicQuery();
tq.Subject = new StringCriterion();
tq.Subject.Includes = new StringInCriterion();
tq.Subject.Includes.Values.Add("string1");
tq.Subject.Includes.Values.Add("string2");
MessageCollection result = ForumHandler.GetQueryResult(tq);
#21337
Jun 26, 2008 16:09
 I cant get it to work as I want with the souloution above, what I realy want to do is making a query that searches "%word1%" OR "%word2%" OR "%word3%" in both subject and text.
Right now i've got the folowing code:
string[] strSearchWords = Request.QueryString["search"].Trim().Split(' ');
CriteriaGroup criteriaGroup = new CriteriaGroup();
MessageCollection topicCollection = new MessageCollection();
TopicQuery topicQuery = new TopicQuery();
topicQuery.Text = new StringCriterion();
topicQuery.Subject = new StringCriterion();
topicQuery.CreateDate = new DateTimeCriterion();
//Set values to filter on
topicQuery.Text.WildCardType = WildCardType.Both;
topicQuery.Subject.WildCardType = WildCardType.Both;
topicQuery.Subject.Includes = new StringInCriterion();
topicQuery.Text.Includes = new StringInCriterion();
topicQuery.Subject.Includes.Values.AddRange(strSearchWords);
topicQuery.Text.Includes.Values.AddRange(strSearchWords);
 //Group Text and subject
criteriaGroup.AddCriterion(topicQuery.Text);
criteriaGroup.AddCriterion(LogicalOperator.Or, topicQuery.Subject);
topicQuery.AddCriteriaGroup(criteriaGroup);
//Order by create date
topicQuery.OrderBy.Add(new CriterionSortOrder(topicQuery.CreateDate, SortingDirection.Descending));
//Get the fitered topic collection
topicCollection = ForumHandler.GetQueryResult(topicQuery);
If I have a topic with the text: Mycket bra forum, I can't get a match if i search with the words Mycket forum, they need to be in the right order to match, witch i want to avoid.
#21348
Edited, Jun 27, 2008 10:15
Is there no soloution for this?
#21534
Jul 01, 2008 9:42
Hi Niklas,
You are correct that wildcards are not possible inside a StringInCriterion, but it is possible to subclass it and override its behavior. In this example I have overriden the default IN (...) statement with a wildcard OR statement. I have also added the possibility to choose which kind of wildcard to use, so there's a little extra code for that also.
// The query execution...
tq.Subject.Includes = new CustomWildCardStringInCriterion();
// The subclassed InCriterion...
public class CustomWildCardStringInCriterion : StringInCriterion
    public CustomWildCardStringInCriterion()
        this.WildCardType = WildCardType.Both;
    public override string GetQuery(string propertyName)
        if (Values != null && Values.Count > 0)
            string parentPropertyName = ((CriterionBase)this.ParentQuery).AssignedPropertyPath;
            StringBuilder queryBuilder = new StringBuilder();
            queryBuilder.Append("(");
            foreach (string val in base.Values)
                if (queryBuilder.Length > 1)
                    queryBuilder.AppendFormat(" {0} ", QueryBase.OR_OPERATOR);
                queryBuilder.AppendFormat("{0} LIKE {1}", parentPropertyName, this.FormatValue(val));
            queryBuilder.Append(")");
            if (NullValueAction == NullValueAction.Include)
                queryBuilder.AppendFormat(" {0} {1} IS NULL", QueryBase.OR_OPERATOR, parentPropertyName);
            return queryBuilder.ToString();
        else
            return string.Empty;
    protected override string FormatValue(string val)
        return String.Format("'{0}'", GetWildCardValue(val, this.WildCardType).Replace("'", "''"));
    protected string GetWildCardValue(string val, WildCardType wildCardType)
        if (wildCardType == WildCardType.None)
            return val;
        else
            StringBuilder sb = new StringBuilder();
            if (wildCardType == WildCardType.Leading || wildCardType == WildCardType.Both)
                sb.Append(QueryBase.PERCENTAGE_OPERATOR);
            sb.Append(val);
            if (wildCardType == WildCardType.Trailing || wildCardType == WildCardType.Both)
            return sb.ToString();
    public virtual WildCardType WildCardType
        get
            return base.GetParameterValue<WildCardType>("WildCardType");
        set
            base.SetParameterValue<WildCardType>("WildCardType", value);
#21565
Edited, Jul 01, 2008 16:56
Thanks a bunch Mattias, this seems to work. And as a bonus we got documentation on how to make our own critierions. Happy day!
Cool
#21590
Jul 02, 2008 9:32
