Found that GlobalFiles was missing an accoiciated <location> tag in the web.config. Don't know how the site could work without it before..
Added:
<location path="Global">
<system.webServer>
<handlers>
<add name="webresources" path="WebResource.axd" verb="GET" type="System.Web.Handlers.AssemblyResourceLoader" />
<add name="wildcard" path="*" verb="*" type="EPiServer.Web.StaticFileHandler, EPiServer" />
</handlers>
</system.webServer>
<staticFile expirationTime="-1.0:0:0" />
</location>
Hi.
I have taken over an EPiServer 5 site from another consulting firm. I recieved their full local code base and have done the following in order to set up my own development environment:
- Copied VPP and database from the sharp production server.
- Clean win7 machine.
- VisualStudio 2008 + .net 3.5
- IIS7
- ApplicationPool integrated.
- Changed the VPP paths in web.config for PageFiles, GlobalFiles and Documents.
The sites compiles without any error and works well on the IIS except 1 thing. All references to GlobalFiles on the site are broken (not found rather). Documents and PageFiles seems to work just fine.
I shouldnt have to change anything else in any config since the codebase I recieved should be running just fine.
Any idé to why the GlobalFiles seems to be the only thing that doesnt work? Maybe some IIS setting, .net or framework setting?
Adam
