Javascript directory forbidden
Hi All,
I'm having some toruble with EPiServer 5. When I load the admin panel nothing works because the required javascript has not been downloaded. Using firebug I found out that this has to do with permissions, as I am getting a 403 response.
How do I set up these permissions? I would have thought that this shuld work out of the box, here is my web.config for the util directory (Util/javascript... is the javascript dir)
<location path="util">
        <system.web>
            <pages>
                <controls>
                    <add tagPrefix="EPiServerUI" namespace="EPiServer.UI.WebControls" assembly="EPiServer.UI"/>
                    <add tagPrefix="EPiServerScript" namespace="EPiServer.ClientScript.WebControls" assembly="EPiServer"/>
                </controls>
            </pages>
            <globalization requestEncoding="utf-8" responseEncoding="utf-8"/>
      <authorization>
        <allow roles="WebEditors, WebAdmins, Administrators"/>
        <deny users="*"/>
      </authorization>
        </system.web>
    </location>
Thanks for any help on this.
#52377
Jul 20, 2011 13:38
Do you have your VPP configuration set up correctly?
#52378
Jul 20, 2011 14:58
Thanks for your response. I just got this sorted, I needed to add a web.config  file with read/exe permissions to the /Util/javascript directory.. fixed my problem.
#52381
Jul 20, 2011 16:09
