Can't get to site. HELP!
I try to go to this url: http://www.karlskrona.se/sv/BarnochUtbildning/Nyheter-Barn--Utbildning/RENT
but get redirected here: http://www.karlskrona.se/Util/login.aspx?ReturnUrl=%2fsv%2fBarnochUtbildning%2fNyheter-Barn--Utbildning%2fRENT%2f
where it tells me to write a name and password. WHAT name? I tried my name and password for episerver but it's still the same
Please help, I don't know what to do.
Image here: http://i612.photobucket.com/albums/tt208/tomtebrolet/Untitled-1.jpg?t=1269779867
The text is swedish, meaning something like:
Name
Password
[ ] Automaticaly log in to this place
[Log in]
If you log in cookies will be used
#38053
Mar 28, 2010 14:40
Hi Lisa
Try going to http://www.karlskrona.se/Util/login.aspx, type in your normal EPiServer username and password. Then go to http://www.karlskrona.se, right click on the page, and see if you get the options Edit Mode and Admin Mode.
Hope this helps.
Frederik
#38055
Mar 28, 2010 19:28
Thank you. I tried but it didn't work :/ It just says 'login failed' like before.
I forgot to say in my previous post, this is not my page, I'm not a mod or anything. I just wanted to be able to view it, that's all.
#38068
Mar 29, 2010 10:50
Ahhh, if its not your site then you won't be able to make any changes to the site settings ;)
You can't see the page as it has been deliberately hidden from you by a web site administrator.
Your best bet is to contact the site owners and let them know that you can't see the page, and if needs be they'll make the changes that Frederick described above.
#38070
Mar 29, 2010 11:33
Ok, I'll do that. Thank you very much :)
#38099
Mar 29, 2010 19:07
