Changing xForm error messages and making them unique per language
I'm trying to create a xform.
If I check "Value must be entered", I cant find the box where I can input the error message I want. All I get is "This field is required" and I'm not able to assign it a CSS class for the error message.
I have tried editing the xForm in a text editor and added
<xforms:alert>* invalid</xforms:alert>
and imported it, but then EPiServer removes the alert.
How do I change it?
And how do I do a translation of this xForm for other languages?
Neil
#31681
Aug 06, 2009 17:14
You can find the different messages in the language files (languageEN.xml, languageNO.xml etc). The xforms messages is located at the end of the file, under the /xforms/requiredfield node.
#31753
Aug 11, 2009 12:06
