Error Executing Websites created from Episerver CMS 5
Hello,
I had installed Episerver CMS Ver 5.1.422.256.
Now if I create the empty Episerver website from Visual Studio 2005 then everything is working fine.
But when I am creating new Website with the help of Manager then I am facing error as
The trust relationship between the primary domain and the trusted domain failed.
  • 1. Also Ichanged the settings as shown in the link below but then also its not working.
 http://world.episerver.com/en/FAQ/Items/The-trust-relationship-between-the-primary-domain-and-the-trusted-domain-failed/
Exception Details: System.SystemException: The trust relationship between the primary domain and the trusted domain failed.
Source Error:
Stack Trace:
[SystemException: The trust relationship between the primary domain and the trusted domain failed.
   System.Security.Principal.NTAccount.TranslateToSids(IdentityReferenceCollection sourceAccounts, Boolean& someFailed) +1167
   System.Security.Principal.NTAccount.Translate(IdentityReferenceCollection sourceAccounts, Type targetType, Boolean& someFailed) +42
   System.Security.Principal.NTAccount.Translate(IdentityReferenceCollection sourceAccounts, Type targetType, Boolean forceSuccess) +46
   System.Security.Principal.WindowsPrincipal.IsInRole(String role) +205
   EPiServer.Web.Hosting.VirtualPathUnifiedProvider.HasFileSystemRights(AuthorizationRuleCollection ruleCollection, FileSystemRights rightsDemand) +145
   EPiServer.Web.Hosting.VirtualPathUnifiedProvider.GetAndValidatePhysicalPathBase(String physicalPath) +209
   EPiServer.Web.Hosting.Versioning.VersioningFileSystem.Init(NameValueCollection config) +107
   EPiServer.Web.Hosting.VirtualPathVersioningProvider..ctor(String name, NameValueCollection configParameters) +198
   System.RuntimeMethodHandle._InvokeConstructor(Object[] args, SignatureStruct& signature, IntPtr declaringType) +0
   System.RuntimeMethodHandle.InvokeConstructor(Object[] args, SignatureStruct signature, RuntimeTypeHandle declaringType) +13
   System.Reflection.RuntimeConstructorInfo.Invoke(BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) +366
   System.RuntimeType.CreateInstanceImpl(BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes) +1036
   System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes) +114
   EPiServer.Web.Hosting.VirtualPathHandler.CreateVirtualPathProviderInstance(ProviderSettings providerSettings) +290
   EPiServer.Web.Hosting.VirtualPathHandler.InitializeProviders(ProviderSettingsCollection providers) +178
   EPiServer.Global.InitializeVirtualPathProviders() +117
   EPiServer.Global.StaticInitialization() +62
   EPiServer.Global.Global_BeginRequest(Object sender, EventArgs e) +119
   System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +92
   System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +64
#28505
Mar 12, 2009 11:57
This problem is related to that you machine can not reach the domain controler or if your domain controler has invalid trust reletionship setup.
The easisiest way to solve this (at least in development environment) is to go to the root folders for the VPP (where all files uploaded by the editors are placed).
Right-click on the folder and select properties, security and advanced.
Stop inheriting the access control list. It will ask if you want to copy or remove - choose remove!
Add a local well known security identifier like everyone and give it full access.
So, when you are done, only Everyone should be in the list an no other users or groups from the domain. Then, the above check will not trigger an exception.
#28523
Mar 12, 2009 16:52
I changed the security properties of the VPP folder and now I am able to execute and run the default page.
Thanks for your help.
Best Regards,
bhavin.chheda@vizualize.com
#28565
Mar 16, 2009 8:13
