Migration error
Hello
When running the Migration Tool I get the following error directly after selecting the 4.62 and 5 R2 web.config: "Validation of configuration files failed. Target errors: Target site failed to respond, reason: Unable to connect to the remote server"
I'm following the migration tool tech note (http://world.episerver.com/en/Documentation/Items/Tech-Notes/EPiServer-CMS-5/EPiServer-CMS-5-R2/EPiServer-CMS-Migration-Tool-11/) and can't find anything helping my case there, not in the migration tool faq (http://world.episerver.com/en/FAQ/Items/EPiServer-CMS-Migration-Tool/) either.
Anyone got any ideas? Help appreciated!
Kind regards,
Patrik
#28150
Feb 23, 2009 10:37
Hi Patrik,
The error seem so point to the target site not running. Can you surf to the 5 R2 site?
#28166
Feb 23, 2009 14:47
Are you doing the migration in Windows XP?  As I understand it, it is not possible to perform the migration on IIS 5.1 (Win XP) due to the fact that it only allows one site at the time to run.
#28169
Feb 23, 2009 15:40
Alas, I've only tried the migration on my dev XP machine so far.
I'll run a migration test on a Win Server and see what happens and get back, if for no other reason than for the sake of documentation. Thanks for the input!
#28191
Feb 24, 2009 12:39
The migration tool works fine on Windows Server 200x machines where you can have multiple sites running - I am performing a migration job right now.
#28193
Feb 24, 2009 14:04
You only need to have the target site (R2 site) running, so running the migration on XP is not a problem.
#28198
Feb 24, 2009 18:45
Hello again
Running the migration tool on W2k3, SQLS2k5, 4.62 and 5 site, gives me a runtime error when the migration starts (that is, after selecting web.configs etc):
System.NullReferenceException: Object reference not set to an instance of an object.     at EPiServer.Migration.LanguageSetting.GetLanguageIds() ...
I'll give the XP migration another try (thanks Mari).
#28290
Mar 02, 2009 10:39
Hello again, just letting you know that migrating using XP worked just fine. Thanks for the help.
Regards,
Patrik
#28648
Mar 17, 2009 13:24
#29829
May 18, 2009 16:15
Im also keeps running into the same problem during my migration.
Anyone got any idea?
* Yes Im running the 5R2 site.
* Yes I can surf to it.
* Yes Im using XP, SQL2005, VS2005/2008, .net3.5, etc....
Regards
//Ola
#37114
Feb 22, 2010 9:01
Hello again
Solved it!
When you setup your 5R2 site you uses port:17000
in webconfig under <sitesettings> replace siteUrl="http://yourComputerName:17000/"
with siteUrl="http://yourComputerName/"
Anyway it solved my problems, hope its helping you aswell.
Regards
//Ola
#37125
Edited, Feb 22, 2010 10:16
I am Getting the following error message while migration.
Error] Target config: Target site failed to respond, reason: The remote server returned an error: (401) Unauthorized.
Anyone have any ideas? Help appreciated!
Thanks & Regards,
Ashok Kumar Gupta
#42417
Aug 23, 2010 10:29
Thanks & Regards,
Ashok Kumar Gupta
#42418
Aug 23, 2010 10:29
Check your securitysettings for the folder. read, write etc...
#42426
Aug 23, 2010 11:06
Hi Ola,
THanks for your reply.
I need to check the security for any specific user?
I am able to brows the site in IE using http://localhost but when I am trying to migrate the site using the Migration tool after specifiy the web.config files for both sites EPI 4.6.4 and EPI CMS 5 R2 then we are getting the following error. Traget site is running under Port 80
Thanks & Regards,
Ashok Kumar Gupta
#42427
Aug 23, 2010 11:30
