Hi Håkon,
What does your siteHosts element look like in web.config? You will need to have an explicit entry for each known domain name. For example...
<siteHosts>
<add name="www.cmsdemo1.com" language="en-US"/>
<add name="www.cmsdemo1.mx" language="es-MX" />
<add name="*" />
</siteHosts>
I was able to get it to work for http://www.cmsdemo1.com/test and http://www.cmsdemo1.mx/test with the above configuration, but when I removed "<add name="www.cmsdemo1.com" language="en-US"/>", I ran into the same problem you had except it always displayed the es-MX variation.
Regards,
Joe
Hi Joe.
from web.config
<siteHosts>
<add name="www.site.se" language="sv" />
<add name="www.site.fi" language="fi" />
<add name="www.site.dk" language="dk" />
<add name="www.site.no" language="no" />
<add name="www.site.com" language="en" />
<add name="*" />
</siteHosts>
it seems that it always chooses the language i first entered the simple webaddress, and not always the masterLanguage branch.
/br
Håkon
As far as I understand the code the simple web address should be unique for both Page Id and Language.
You can not have the same simple web address for two pages or language branches.
The stored procedure netQuickSearchByExternalUrl returns a list but if you look at the code in EPiServer.DataAccess.PageQuickSearchDB.SimpleAddressToInternal() it is only intended to be used in an enterprise scenario with multiple start pages. It is hard coded to only use the first result containing Page Id and Langauge.
Hi.
I have a Episerver CMS5 r2 site with globalization enablet.
Have mapped Different Domains to different languages in web.config and this works fine.
My problem is that when i Enter the same simple webaddress on the same node but for different languages it alwas reverts to the masterlanguage branch.
I have
site.com/simple
site.se/simple
When i enter site.com/simple everything works fine
with site.se/simple it chooses the .com page and not the se page.
br
Håkon
