Upgrade problem R2 SP2 - Object reference not set to an instance of an object
After upgrading to R2 SP2 I can no longer login to edit or admin. I get this error:
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
Stack Trace:
[NullReferenceException: Object reference not set to an instance of an object.]    EPiServer.DataAccess.DataAccessBase.Execute(Action action) +85    EPiServer.DataAccess.WindowsProviderDB.SynchronizeGroups(String userName, String[] groups) +85    EPiServer.Security.WindowsRoleProvider.GetRolesForUser(String username) +124    System.Web.Security.RolePrincipal.IsInRole(String role) +164    EPiServer.Security.VirtualRolePrincipal.IsInRole(String role) +101    System.Web.Configuration.AuthorizationRule.IsTheUserInAnyRole(StringCollection roles, IPrincipal principal) +123    System.Web.Configuration.AuthorizationRule.IsUserAllowed(IPrincipal user, String verb) +256    System.Web.Configuration.AuthorizationRuleCollection.IsUserAllowed(IPrincipal user, String verb) +199    System.Web.Security.UrlAuthorizationModule.OnEnter(Object source, EventArgs eventArgs) +8771768    System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +68    System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +75
Version Information: Microsoft .NET Framework Version:2.0.50727.3053; ASP.NET Version:2.0.50727.3053
If I go to the site I get this error:
Source Error:
Stack Trace:
[NullReferenceException: Object reference not set to an instance of an object.]    EPiServer.DataAccess.DataAccessBase.Execute(Action action) +85    EPiServer.DataAccess.PageQuickSearchDB.FindByExternalUrl(String path) +197    EPiServer.Web.SimpleAddress.SimpleAddressToInternal(UrlBuilder url, Object& internalObject) +66    EPiServer.Web.FriendlyUrlRewriteProvider.ConvertToInternalInternal(UrlBuilder url, Object& internalObject) +164    EPiServer.Web.FriendlyUrlRewriteProvider.ConvertToInternal(UrlBuilder url, Object& internalObject) +303    EPiServer.Web.UrlRewriteModule.HttpUrlRewriteToInternal(UrlBuilder url) +313    EPiServer.Web.UrlRewriteModuleBase.BeginRequestEventHandler(Object sender, EventArgs e) +158    System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +68    System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +75
#33490
Oct 14, 2009 14:19
I guess the upgrade program was having a bad day. Comparing a working web.config I saw that this line was missing from the <httpModules> section!
<add name="InitializationModule" type="EPiServer.Web.InitializationModule, EPiServer" />
#33491
Oct 14, 2009 14:33
