how to compage properties which are pagereference
Wu
Wu
#23851
Sep 17, 2008 15:43
You can get your property by creating a helper class like this:
public static PageReference GetPropertyPageReference(PageData pd, string propertyName)
            return ((pd[propertyName] as PageReference) ?? PageReference.EmptyReference);
 You call it like this:
PageReference pr = GetPropertyPageReference(YourPage, YourPropertyName);
 If your PageReferences isn't EmptyReference (PageReference.EmptyReference), then you can compare your PageReferences by using it's ID property like this:
If(PageRefOne.ID == PageRef2.ID)
//Do your thing
 OR use:
PageRefOne.CompareTo(PageRef2)
 -Kjetil Simensen
#23853
Edited, Sep 17, 2008 15:54
Wu
could I do something like: PropertyCriteria responsibilities = new PropertyCriteria();
                    responsibilities.Type = PropertyDataType.Pagereference;
                    responsibilities.Name = "Responsibilities";
                    responsibilities.Condition = CompareCondition.Equal;
                    responsibilities.Value = ????                    criteriaCollection.Add(responsibilities);
#23857
Sep 17, 2008 16:40
Not tried to use it in a FindPagesWithCriteria. Do you have to use this or can you make your own filter/search?
-Kjetil
#23866
Sep 17, 2008 17:46
Hi Hua Wu!
Could you let us know what data type you selected in the combo box when you added the "Responsibilites" property.
/Fredrik
#23868
Sep 17, 2008 18:23
