EPiServer.Web.WebControls.InputDate
I have tried to put an InputDate webcontrol on a page. But I got a javascript error. The onclick event on the InputDate is "EPi.CreateDateBrowserDialog". This javascript method is in "UI/javascript/system.js". But in web config the UI folder only allow roles WebAdmins and WebEditors.
Am I missing something? My idea is that I should be able to use this webcontrol even for anonymous users.
Regards Hans
#20779
Jun 12, 2008 6:57
I have solved it but I'm not certain if it is meant to be solved like this
To say before I start: The "SecureUI" folder I write about is the EPiServer UI folder, I named it "SecureUI" at installation.
I had help from the following:
http://labs.episerver.com/en/Blogs/Mari-Jorgensen/Dates/111987/112010/Lessons-learned-Module-Conversion/
where I found that I have to register the following:
<script type="text/javascript" src="<%= EPiServer.UriSupport.ResolveUrlFromUtilBySettings("javascript/episerverscriptmanager.js") %>"></script>
<script type="text/javascript" src="<%= EPiServer.UriSupport.ResolveUrlFromUIBySettings("javascript/system.js") %>"></script>
<script type="text/javascript" src="<%= EPiServer.UriSupport.ResolveUrlFromUIBySettings("javascript/system.aspx") %>"></script>
I do this in my masterpage.
But if I'm not logged in as admin or editor I get an javascript exception because I dont have access to "SecureUI/javascript/system.aspx".
I have read this before, about Virtual Path Providers and UrlMappings
http://epicms.blogspot.com/2007/03/no-alternate-files-and-it-really-makes.html
So I added the following urlmappings in web.config:
<virtualPathMappings>
    <add url="~/Util/javascript/system.js" mappedUrl="~/SecureUI/javascript/system.js" />
    <add url="~/Util/javascript/system.aspx" mappedUrl="~/SecureUI/javascript/system.aspx" />
</virtualPathMappings>
And I also changed the following lines in my masterpage, ResolveUrlFromUtilBySettings instead of ResolveUrlFromUIBySettings:
<script type="text/javascript" src="<%= EPiServer.UriSupport.ResolveUrlFromUtilBySettings("javascript/system.js") %>"></script>
<script type="text/javascript" src="<%= EPiServer.UriSupport.ResolveUrlFromUtilBySettings("javascript/system.aspx") %>"></script>
Now it works! But is it meant to be done like this?
Regards Hans
#20782
Jun 12, 2008 8:24
That should be fine as far as I know. I did some tests using the InputDate control some time ago, but I just added a new location node to my web.config and grantedfor everyone access to the javascript folder.
#20806
Jun 13, 2008 9:47
Thanks Greger!
/Hans
#20857
Jun 16, 2008 11:20
