Url Rewriting Problem
I have just moved a new site to the clients staging server. When browsing to the start page we get the following error when friendly url rewriting is enabled -
Object reference not set to an instance of an object.
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
Stack Trace:
System.Web.HttpContext.RewritePath(VirtualPath filePath, VirtualPath pathInfo, String queryString, Boolean setClientFilePath) +40
System.Web.HttpContext.RewritePath(String filePath, String pathInfo, String queryString, Boolean setClientFilePath) +51
EPiServer.Web.UrlRewriteModuleBase.BeginRequestEventHandler(Object sender, EventArgs e) +585
System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +92
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +64
This only happens on the home page and if I append the Url with '/en' it works fine.
Paul
#19746
May 01, 2008 15:32
