I'v defined the following in my web.config
<siteHosts>
<add name="site.com.local" language="en" />
<add name="site.se.local" language="sv" />
<add name="*" />
</siteHosts>
works like a charm.
Now, if I want to change language when surfing around on one site to the other, can I in a easy way change the host defined in siteHosts aswell?
Today i use the following:
return string.Format(@"<a href=""{0}"" class=""{1}"">{2}</a>", EPiServer.UriSupport.AddLanguageSelection(pd.LinkURL, pd.LanguageID), pd.LanguageBranch, Translate("/lang/" + pd.LanguageBranch));
I guess I can use EPiServer.Configuration.SiteElement to obtain the siteHost, but is there a method that can do this automagically?
